GSR cluster HELP.........................asap
Old Mar 18, 2003 | 11:13 AM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
Default GSR cluster HELP.........................asap
okay here is the thing i put in the GSR cluster into my hatch everything else is working but the speedometer
when i turn the ignition the speedometer reads 50mph but the car is not moving.
could someone plz try and figure this out
Old Mar 18, 2003 | 11:33 AM
Spade's Avatar
Default Re: GSR cluster HELP.........................asap (MR.RED'89)
did u re-wire or just plug it in?
Old Mar 18, 2003 | 12:44 PM
1bad-eg's Avatar
What year cluster is it?
Old Mar 18, 2003 | 01:36 PM
^Sammy]!.'s Avatar
Default Re: GSR cluster HELP.........................asap (1bad-eg)
89 hatch 97 gsr cluster 94+ gsr harness 92+ civic electronic vss
someone plz help me out here
this is driving me crazy
[Modified by MR.RED'89, 2:38 PM 3/18/2003]
Old Mar 28, 2003 | 11:46 AM
1bad-eg's Avatar
Definitely check out the harness to the cluster. Sounds like you have a wire or two mixed up. My buddy did the same thing to his crx and got it to work. It took him a while but it payed off in the end.
Old Mar 28, 2003 | 06:28 PM
^Sammy]!.'s Avatar
hey EG could you find out what wires did your buddy switch around?
Old Mar 28, 2003 | 08:29 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
If you move forward does the speedometer actually move as well. I had the same thing happen on mine. I had everything wired correctly, I started fresh three or four different times. Then from suggestion of a friend I removed the needle and repositioned it back to zero. Worked fine. I used a fork to pry up the needle and reposition it to zero, he stated he had removed it previously so it could have just been that. If you believe all the wiring is correct I go for it, I tried a few different configurations some led me to the same problem. Speedometer set to 40mph, sometimes both the speedometer and the tachometer, finally I removed the needle as suggested.
Old Mar 28, 2003 | 08:45 PM
Turbo Powa's Avatar
Default Re: GSR cluster HELP.........................asap (INVALID)
thats exactly what I did with mine.
Old Mar 28, 2003 | 08:49 PM
^Sammy]!.'s Avatar
Default Re: GSR cluster HELP.........................asap (Panda EK)
okay but mines the speedometer does not go past 50mph it goes up there when i turn the ignition and stays there and the mileage does not read either
how is the vss connected?
the vss i have has 3 wires black,yellow&white,yellow&blue
Old Mar 28, 2003 | 09:13 PM
crx8psi's Avatar
I have the same problem its stuck at 42 mph when I turn the ignition on I dont have a vss hooked up yet.
Old Mar 28, 2003 | 09:53 PM
INVALID's Avatar
So neither of you are able to get past the original mph it sets at when the key is turned to the ACC position?
Old Mar 28, 2003 | 09:56 PM
^Sammy]!.'s Avatar
yeap just like that
when i turn the ignition to ACC it goes upto 50mph and stays there until i turn the car off.
i was told that its cause it needs a ground wire
could that be it Invalid?
Old Mar 28, 2003 | 10:03 PM
INVALID's Avatar
Sorry, what I meant to say is, will the speedometer go past that set MPH when you attempt to drive the car. Mine had the same symptoms, took the car for a quick drive to determine if everything was in fact working when I drove the the speedometer would continue to move as if just positioned incorrectly. I would turn the key to the ACC position and it would come to rest at 40 MPH until I was actually moving forward.
Old Mar 28, 2003 | 10:07 PM
^Sammy]!.'s Avatar
nah it doesnt move past 50mph it goes up to there and stays there
how did u wire your vss?
Old Mar 28, 2003 | 10:23 PM
INVALID's Avatar
Only problem is your civic did not come standard with VSS so you actually had to put another model VSS in your civic, correct? Mine already had VSS, I just need to connect the proper wires for it. I had some information as to one person who installed a GSR cluster from a 90s model civic and go it to work, only my recent topics will not go back far enough to find out which member it was.
Old Mar 28, 2003 | 10:26 PM
^Sammy]!.'s Avatar
yeah i put in a 92+ electronic vss
did u by any chance print that information?
how long ago did you do this?
Old Mar 28, 2003 | 10:31 PM
INVALID's Avatar
The wiring diagram I used or the person who installed the VSS in the 90s civic? If you need the wire diagram I have that, but I don't recall the member who installed the VSS in his 90s civic to get this to work.
EDIT: same problem, but again not a 90s model civic
https://honda-tech.com/zerothread?id=437408
[Modified by INVALID, 2:32 AM 3/29/2003]
Old Mar 28, 2003 | 10:36 PM
^Sammy]!.'s Avatar
Invalid can you post that for me or send it to my email im getting an error when i click on the link
email: siderazeref9@aol.com
Old Mar 28, 2003 | 10:45 PM
INVALID's Avatar
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
_______
Here is another
This will all depend on the wire harness and year cluster you are using.
Old Mar 28, 2003 | 11:11 PM
^Sammy]!.'s Avatar
Okay Invalid how does the wiring for the VSS go
black=ground
yellow&white=switch power
yellow&blue=signal
where does the yello&white go connected?
where does the yellow&blue go connected?
Old Mar 29, 2003 | 01:05 AM
INVALID's Avatar
On mine I had to go the yellow blue. Again mine came stock with VSS so don't take this as gospel, but yellow blue is what I used.
Old Mar 29, 2003 | 05:50 AM
integra6650's Avatar
where was this diagram when i swapped my whole dash a little late but thanks alot for posting it ill go back and double check my work
Old Mar 29, 2003 | 12:11 PM
Loaded_Pistol's Avatar
Default Re: GSR cluster HELP.........................asap (integra6650)
i am doing the same shittt with my cluster off a 95 GSR to a 96 Civic DX
did my car came stock with VSS already or do i also need a kit.....
On DX there are no RPm's showing so will everything be functional including the rpm's/mph
[Modified by Loaded_Pistol, 9:12 PM 3/29/2003]
Old Mar 29, 2003 | 03:58 PM
INVALID's Avatar
Default Re: GSR cluster HELP.........................asap (Loaded_Pistol)
You should have all the same connections behind your gauge cluster to connect on that GSR cluster, the wiring varies though from the one above. Getting the RPM to work should not be a problem, regardless of the fact yours did not come with a tachometer. Try this one:
http://www.fifthgearonline.com/installs/gsrcluster2.htm
[Modified by INVALID, 7:59 PM 3/29/2003]
Old Mar 29, 2003 | 08:34 PM
INVALID,
props for your help dude,
I'll most definitely update you within a week for sure as to what is going on with the install.
Later
vndsd1
Northern California (Sales)
Apr 14, 2010 10:50 PM
JDM-jerm
Nov 26, 2008 10:52 AM
Mendes
Jul 24, 2006 04:50 PM
^Sammy]!.
13
Mar 5, 2003 06:09 PM
