Piston to wall tolerance?
Old Mar 18, 2003 | 09:28 AM
advanracing62's Avatar
Default Piston to wall tolerance?
Anyone know what the stock piston to wall tolerance is for an ITR? also what is the ring gap?
Old Mar 18, 2003 | 12:34 PM
sgT's Avatar
sgT
Default Re: Piston to wall tolerance? (advanracing62)
piston-wall clearance .0006-.0014"
Old Mar 18, 2003 | 09:24 PM
Default Re: Piston to wall tolerance? (sgT)
Thanks SGT... I'll let the kid know!
Old Mar 18, 2003 | 09:59 PM
b19coupe's Avatar
I could be wrong, but that sounds a wee bit snug. The spec on my JE's is .003". I thought the stock B18C1/5 spec was around 0.0015" the last time I looked, but I will have to check the S.M. tomorrow.
Old Mar 19, 2003 | 04:51 AM
Charlie Moua's Avatar
is it true that with a looser piston to wall clearance there is more wear on the wall and rings?
I heard it was a common thing with FORGED pistons that are low silicone and that do expand a lot when the temp goes up that is why they HAVE TO run a looser piston-to-wall clearance.
please educate me on this.... even though sorta off topic
Old Mar 19, 2003 | 05:39 AM
Default Re: Piston to wall tolerance? (Charlie Moua)
anyone know the ring gap for factory pistons?
Old Mar 19, 2003 | 05:44 AM
IN VTEC's Avatar
That piston-to-cylinder wall clearance isn't too snug for factory pistons. It's what the manual specifies.
Ring end gaps:
Top: .008" - .014"
2nd: .016" - .022"
Oil: .008" - .020"
Old Mar 19, 2003 | 07:06 AM
b19coupe's Avatar
Default Re: Piston to wall tolerance? (IN VTEC)
Silly me, I should never have doubted SGT.
Service manual: Standard 0.0004-0.0016"
Service limit-0.002"
SGT is the man.
Old Mar 19, 2003 | 07:16 AM
PhatOptimo's Avatar
Default Re: Piston to wall tolerance? (b19coupe)
Forged pistons swell when they get hot. OEM pistions don't as much so with OEM slugs you can run tighter piston to cyl wall clearance without the piston seizing.
ADDED: Also a bigger piston say 84mm will require larger piston to cyl. wall clearance than 81mm.
[Modified by Phat_Optimo, 10:41 AM 3/19/2003]
TwoKSiR
Aug 14, 2006 02:15 PM
black99x
Aug 11, 2006 07:40 AM
true
Jun 21, 2003 03:57 PM
Ri5e
Aug 7, 2002 08:31 PM
