****Extrude Hone***
Old Mar 18, 2003 | 03:57 AM
Charlie Moua's Avatar
Default ****Extrude Hone***
well I'd like to know more about this process and how benifical/cost effective it can be. I was thinking about getting my intake manifold "extrude honed" for better flow characteristics in the higher rpm range.
*is it worth it
*which is better extrude hone or porting your manifold?
*has anyone done it? give me your experince?
Old Mar 18, 2003 | 04:41 AM
BabyDaddy's Avatar
Default Re: ****Extrude Hone*** (Charlie Moua)
Extrude honing is done by pushing an abrasive "goo" through the part at pressure. It's pretty expensive from what I understand. I just hand-ported mine.
Old Mar 18, 2003 | 05:30 AM
liquid51's Avatar
Default Re: ****Extrude Hone*** (BabyDaddy)
some companies wil do a port job by hand and then a light extrude hone to remove turbulent areas and any burs in the head. I think he's right though, it is pretty expensive.
Old Mar 18, 2003 | 05:50 AM
Default Re: ****Extrude Hone*** (liquid51)
Hum... in what area of expesive are whe taking about? take for example a intake manifold.
a)$100-250
b)$250-350
c)$350-500 ..????
Old Mar 18, 2003 | 06:54 AM
GM2000ITR's Avatar
New User
Last time I inquired, an IM runs about $500+/-.
Old Mar 18, 2003 | 03:17 PM
19924ws's Avatar
Default Re: ****Extrude Hone*** (GM2000ITR)
That process for porting isn't worth it, for removing the rough spots as mentioned above it is ok. Get a real port and polish on it. That shouldn't be more than 250. If you would consider spending 500 for porting a stock intake you should just get an aftermarket one. Mike
Old Mar 18, 2003 | 03:58 PM
Rob Dizzle's Avatar
what are your mods?
there are a lot of other things that I am guessing you can do.
so a search,because someone had their itr intake manifold dynoed with befofe/after extrude hone
they didnt get that much power.
you can definetly find more power in other areas
Old Mar 18, 2003 | 04:15 PM
Default Re: ****Extrude Hone*** (Bob-DC2)
thanks guys... I'll save my money on other parts instead.
Hatchorama
Jun 11, 2007 04:40 PM
TypeRcivic
Feb 10, 2005 01:59 PM
turboman
Apr 7, 2004 06:39 PM
Rhetoric
15
Sep 17, 2003 09:00 AM
woodog
May 18, 2001 03:07 PM
