Head milled 35thou,which head gasket????
stock you jackass...j/k...why did they take 35 thousandths off?
[Modified by CART fan, 1:15 PM 3/18/2003]
35/1000's isn't a super duper crazy mill job, closer to 40/1000+ is though.
Stock/OEM should be your main choice of headgasket though.
(if you haven't yet) You should look into getting some adjustable camsprockets to correct the cam timing once you put that milled head on your block.
Does anyone know how much milling your head will affect cam timing?
Example: For every 10 thousandths off the head your cams will need to be advanced ??? degrees.
my machcine shop teacher says that every 10/1000 will affect timing about 1 degree. also forevery 10/1000 it should raise compression almost 10psi on a compression test.
[Modified by SanoJDm, 3:38 PM 3/18/2003]
just get a Honda OEM spec one. the raise in compression ration will most likely not make that much of a difference. I would not worry about detonation either.
No... my head is a b16a head and I have the JE 5.7 dome pistons and a Cometic .067" gasket... If you're worried about it, talk to cometic. they'll make u a fat-*** gasket if u really want it.
Harry
Harry
