proportioning valve
Old Mar 17, 2003 | 11:09 PM
asiandoood's Avatar
Default proportioning valve
i got a GSR brake setup ready to be put in, but I need a proportioning valve. i've heard i need the 40/40 valve. which ones would bolt into my 92 civic dx?
94-00 RS/LS w/o ABS?
88-91 EX Civic?
92-95 Civic Si w/o ABS?
i need avg. pricing on them new and used also so i know what to look for.
or ...can i run with a stock DX prop valve safely?
TIA
Old Mar 18, 2003 | 01:04 AM
JSJ EG6's Avatar
Default Re: proportioning valve (asiandoood)
integra rs proportion vavle and m/c and brake booster.you still can run ur stoxk dx proportion vavle m/c and brake booster but when you brake the brake pedal will go down more.
Old Mar 18, 2003 | 07:11 AM
CXHatchback's Avatar
Default Re: proportioning valve (TEAM JSJ)
also 90-93 tegs had 4040 valves and those bolt right up. I got mine at a junkyard for $15
Old Mar 18, 2003 | 12:04 PM
porsche997dc2's Avatar
Default Re: proportioning valve (CXHatchback)
Yes, you do need 40/40 valve.
Old Mar 18, 2003 | 06:09 PM
asiandoood's Avatar
awesome. my biggest fear was needing to bend or reflare lines. im probably going to do the ITR MC with the 90=93 integra prop valve. thanks for the help.
shopa
Dec 2, 2015 01:30 PM
viciousef9
Suspension & Brakes
Nov 9, 2008 02:40 PM
lollypopking
Jan 3, 2005 05:21 PM
midnightdarknes5
May 20, 2004 11:59 PM
