b16 burning oil
Old Mar 17, 2003 | 08:20 PM
customx_'s Avatar
New User
Default b16 burning oil
after 2800 miles, about 2 qts is left. is it the shitty mobil durablend oil or my rings gone bye bye?
Old Mar 17, 2003 | 08:24 PM
nsxmatt's Avatar
Default Re: b16 burning oil (usdmRob)
Hard to tell. Does your car smoke? Do a compression test and go from there. Also are you leaking oil? Synthetic will start to leak in places that normally wouldn't have leaked before. Just depends but chances are it's rings or valve seals.
Old Mar 17, 2003 | 08:33 PM
customx_'s Avatar
New User
Default Re: b16 burning oil (nsxmatt)
wut u mean smoke? nope, no oil leak from where i can see.
Old Mar 17, 2003 | 08:40 PM
SymphonyX's Avatar
Don't feel bad, My car eats oil badly. I don't know if i had a problem , i have to look. But i did an oil change and 1000 miles later, i had to put in 4 qt of oil. My guy said that i am high compression so it eats it. WTF i know....
Old Mar 17, 2003 | 08:43 PM
customx_'s Avatar
New User
my motor is stock and i seldomly hit vtec
Old Mar 17, 2003 | 08:53 PM
SymphonyX's Avatar
Do you Always Drive HArd?? Popping V-tec alot??
Old Mar 17, 2003 | 09:54 PM
poo flinger
Guest
Posts: n/a
Default Re: b16 burning oil (SymphonyX)
Popping vtec? Last time I checked vtec engages.
Old Mar 18, 2003 | 05:56 AM
nsxmatt's Avatar
Default Re: b16 burning oil (I can't believe this ****)
Popping V-tec?
Anyway, the only way you will know why you are burning oil is to do a compression and leakdown test. You say it's not leaking so the only way for you to lose oil is through the exhaust so it is burning it at sometime. Maybe you just don't notice the smoke.
Swapped94
Jan 12, 2009 04:54 PM
d!ckface
16
Jul 27, 2007 04:35 PM
sepulchral
Mar 26, 2006 04:36 PM
lakerschamp2000
Jan 26, 2004 05:53 PM
