OBD I B16 head fit on OBD II LS block?
Old Mar 17, 2003 | 08:05 PM
Sassafrass's Avatar
Default OBD I B16 head fit on OBD II LS block?
Hey I found a guy with a first gen OBDI B16 head and I want to buy it, but I have a 99 OBDII LS motor, obviously this is for ls/vtec, now can I use this head?
My next question is he has a B16 and a GSR, but the GSR is $100 more, which one should i buy? My plans are for a daily driven ls/vtec, that will have new pistons, rods, cams and valve train, port and polished head, new IM etc..
Old Mar 17, 2003 | 08:30 PM
sshaikh01's Avatar
Default Re: OBD I B16 head fit on OBD II LS block? (Sassafrass)
you would need to swap out things like dist. im, ect
Old Mar 17, 2003 | 09:00 PM
jumpmann23's Avatar
From: Your really lame if you dock my points, WA, 98033
if your converting the head to obd2 then you need a obd2 distrbutor, obd2 vtec ecu, obd2 injectors.
Old Mar 17, 2003 | 09:04 PM
BackSideSA's Avatar
Default Re: OBD I B16 head fit on OBD II LS block? (ek9folife)
i would imagine so....i am rocking an obdII motor with an obdI ecu. and i didnt have to change anything. if you use an obdI head then you will be able to use an obdI ecu (fully programmable rather then the obdII)
Old Mar 17, 2003 | 09:09 PM
Sassafrass's Avatar
Default Re: OBD I B16 head fit on OBD II LS block? (HybridHackBatch)
Maybe I didn't say it properly, I'm not converting the head to OBDII, I have an OBDII LS motor and I want to put an OBDI head on, so I'm going OBDII - OBDI, there should be a problem with that once I get the ECU right?
Old Mar 17, 2003 | 09:16 PM
jumpmann23's Avatar
oh you should be fine then just get the jumper harness obd2 to obd1 and then run obd1 ecu.. i dont think theres anymore to it than that. you might have to do some rewiring for the injectors.ask katman or Kenji they can hook you up
Old Mar 17, 2003 | 10:09 PM
J2turbo21's Avatar
Yes it will but depending on what car its going on you need to make sure its obd 1 or 2/
Old Mar 18, 2003 | 04:40 AM
Sassafrass's Avatar
Default Re: OBD I B16 head fit on OBD II LS block? (J2turbo21)
I have a 93 civic DX, so I believe my car is OBDI, so it should work if I get the head and new ECU right? and that wiring harness converter?
Old Mar 18, 2003 | 05:47 PM
Sassafrass's Avatar
ttt
3Rd GeAr PuLl
Jan 15, 2007 05:59 AM
.doeboyfresh.
Aug 6, 2004 06:07 AM
the DA in HONDA
Jul 26, 2004 11:37 PM
my_slow_civic
Mar 14, 2004 05:28 AM
sparq
May 5, 2002 09:27 AM
