Need information ASAP on battery issue.
Old Mar 17, 2003 | 07:43 PM
bluesaint's Avatar
Default Need information ASAP on battery issue.
Well, since last week my car will not start, all the accessory would work, and when i turn the key i would hear the starter clicking away and see the lights flashing with each click on the dash.
I thought it was the battery after reading:
https://honda-tech.com/zerothread?id=277018
So i ordered a new T1R battery, dropped it in, jump started since I was seeing the same scenario as before, but figured it might just be the battery isn't shipped fully charged. After driving it around for 40 minutes, stopped the car, shut it down, and it won't start backup.
Alternator and starter has only 11k miles on it.
Any one has suggestions? This sucks.
Old Mar 17, 2003 | 08:00 PM
TypeR00_0371's Avatar
Default Re: Need information ASAP on battery issue. (bluesaint)
The Honda Alternators aren't big enough to charge the battery, Try to trickle charge it on the lowest charger setting, leave it for about 4-6 hrs, and try it then... If you have access to a meter, you can check it that way too...
[Modified by TypeR00_0371, 5:01 AM 3/18/2003]
Old Mar 17, 2003 | 08:05 PM
bluesaint's Avatar
Default Re: Need information ASAP on battery issue. (TypeR00_0371)
So your saying even if i leave it on idle for 2 hours or even drive it for 2 hours, the thing will not charge? What good is a alternator?
Old Mar 17, 2003 | 08:31 PM
bluesaint's Avatar
anyone?
Old Mar 17, 2003 | 08:42 PM
SymphonyX's Avatar
Do you have AEM pullies on your car?? i had an alternator pully and that **** drain the **** out of my battery. Then i went back to the OEM pully and it solved the problem
Old Mar 17, 2003 | 08:50 PM
bluesaint's Avatar
Default Re: Need information ASAP on battery issue. (SymphonyX)
Stock pully.
Old Mar 17, 2003 | 08:57 PM
SymphonyX's Avatar
your altenator may not be holding the charge. do this, start your car, and pull the neg. battery off, if your headlights get really dim or the ccar stops. you have a no charge in the alternator. check the fluid in the battery too, if its low, put distill water in it. other then that, i don't know what to tell you. do you have a sound system thats connected to it?
Old Mar 17, 2003 | 09:10 PM
bluesaint's Avatar
this is with a brand new dry cell battery (fully charged) no amps or stereo of any kind, i can pull the negative off after car starts and nothing gets dimmed.
Old Mar 18, 2003 | 05:15 AM
PupaScoopa's Avatar
Check some auto parts stores in your area. If you have Advance Auto Parts, they'll check your charging system for free.
Old Mar 18, 2003 | 06:51 AM
Jon Black's Avatar
Alternators are not designed to charge your battery. They are designed to put out enough current to run the car and keep you current battery leavel maintained. So if your battery is weak, its potential energy will most likely not climb much higher than it was when you started the car.
If you have a deep cycle battery, you will need to give it a deep cycle charge. Batteries are not magic. What you put in is what you get out. I would recommend charging the battery for at least 2 or 3 times longer than the deep cycle reserve in minutes.
For example, if the reserve is 200 minutes, charge it for 400 or 600 minutes. This is because the charging curve may not be linear, and if it is exponential, you will need extra charging time.
Do this and you should be good. If you have removed the negative terminal while the car was running and it still ran fine then you are OK on the alternator issue.
A battery's main function is to START your car.
Jon Black
Old Mar 18, 2003 | 10:49 PM
bluesaint's Avatar
Default Re: Need information ASAP on battery issue. (Jon Black)
Funny thing, I installed Tommy Gunn's earthing system this morning and the car can start with it installed.
I checked my stock two engine grounds and they are still connected and the cables still look good. So i guess there might be damage to the stock ground cables that i can't see with the naked eye.
Old Mar 18, 2003 | 10:53 PM
ABTDer's Avatar
yeah you might have to change your stock ground cables... get some nice thick ones to ground it properly. there's probably build up corrosion and all that nice stuff. it might solve your problem
Old Mar 18, 2003 | 11:53 PM
94hondaLS's Avatar
Default Re: Need information ASAP on battery issue. (PupaScoopa)
a good alternator should put out at least 13.8 volts. and when you do a battery load test it shouldnt drop below 9 volts. These tests require a volt meter. Since everything is practically new there may be too much resistance in the cables. so the charge from the alternator isnt reaching the battery. hope any of this info helps
[Modified by 94hondaLS, 12:56 AM 3/19/2003]
importfanatic17
Feb 26, 2007 12:34 PM
whophlungpoo
May 29, 2006 07:39 PM
KloC 95 EG
Dec 9, 2005 02:16 AM
95greenteg
Nov 29, 2004 02:56 PM
eric416
Jun 22, 2004 09:33 AM
