Gapping spark plug help
I bought one of those big round spark plug gapper to gap the spark plugs I plan on changing. My question is, do I just force the spark gapper inbetween the fire tip of the plug and just move in until it's in proper range? Like force the movement until it's within gap specify range?
My wire-type gapper has little black flat things sticking out with notches in them. You put the notch around the outer terminal like shown in the pic, and bend it just slightly. Then you check it with the proper size wire loop. I use the .050" wire on mine.
