Gapping spark plug help
Old Mar 17, 2003 | 07:01 PM
mickey513's Avatar
Default Gapping spark plug help
I bought one of those big round spark plug gapper to gap the spark plugs I plan on changing. My question is, do I just force the spark gapper inbetween the fire tip of the plug and just move in until it's in proper range? Like force the movement until it's within gap specify range?
Old Mar 17, 2003 | 07:56 PM
Yyz's Avatar
Yyz
Default Re: Gapping spark plug help (mickey513)
Yes, or at least that’s what I did. But be careful not to force it to hard or the electrode will break. Hope this helps.
Old Mar 17, 2003 | 08:06 PM
ingrate's Avatar
25 Year Member
you have the flat disc-shaped gapper, correct? i don't trust the accuracy of those things. Better to get a wire-type gapper like in the pic or use a feeler gauge like the kinds you use for valve adjustments. Personally i use a flathead screwdriver and carefully pry it open and then gently push down on the electrode against the table 'til it's the proper gap.
Old Mar 17, 2003 | 08:11 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Gapping spark plug help (ingrate)
My wire-type gapper has little black flat things sticking out with notches in them. You put the notch around the outer terminal like shown in the pic, and bend it just slightly. Then you check it with the proper size wire loop. I use the .050" wire on mine.
ravinaziankid
Aug 14, 2012 05:25 PM
sacalait59
Apr 25, 2010 02:52 PM
imzjustplayin
Dec 22, 2008 01:01 PM
unknown2
Oct 10, 2006 11:59 AM
Killashahmafia
Sep 14, 2003 02:02 PM
