HELP..i'm runnin lean and cant' figure out safc
Old Mar 17, 2003 | 04:50 PM
ridnmyhonda's Avatar
Default HELP..i'm runnin lean and cant' figure out safc
well my t3 was a nice turbo and air/fuel was perfect ran rich when i got on it...so i did a new install with my t3/t4 and it only runs lean...i can't figure out how to get it rich...i have a safc, and fmu..and also a fuel pump i didn't connect it yet...cuz i didn't knwo if i should...please help...i suck w/ safc hack..thanks
Old Mar 17, 2003 | 04:51 PM
Daniel's Avatar
Default Re: HELP..i'm runnin lean and cant' figure out safc (ridnmyhonda)
no fuel injectors? if you want to run the hack, you're supposed to wire up the SAFC and install 440/450 fuel injectors. you won't need the FMU but the fuel pump wouldn't hurt.
[Modified by Daniel, 1:53 AM 3/18/2003]
Old Mar 17, 2003 | 05:06 PM
dmotoguy's Avatar
Default Re: HELP..i'm runnin lean and cant' figure out safc (Daniel)
i thought you where only running 3 psi or so until you got a blow off valve etc... how are you running lean? just richen up the area where you are running lean... cant be too hard to figure out...
freeplay's Avatar
andrew- you're not doing the safc hack, you don't have big injectors. You're probably running lean because you set your safc at -6% or whatever you told me all the way across the board. Change it to 0% and see what happens. Be careful.
Old Mar 17, 2003 | 06:47 PM
Default Re: HELP..i'm runnin lean and cant' figure out safc (HtwentytwO)
i was kiddin about 3 psi., it's quick as hell now...i put my 2.5" d/p in today and ran open d/p...WOW it's quick..now i'm looking for some 440's...
Old Mar 17, 2003 | 06:51 PM
vha27's Avatar
what?! i thought goin negative leaned it out
Old Mar 17, 2003 | 06:52 PM
Default Re: HELP..i'm runnin lean and cant' figure out safc (vha27)
it does...thats why i had it at -6
Kutsuju_SLeePER
Jul 26, 2004 12:10 PM
wzcb08
May 11, 2003 07:36 PM
Slo_Akord
Dec 30, 2002 03:34 PM
pelotudo
Sep 14, 2002 12:35 PM
Hybrid
Sep 13, 2002 05:56 AM
