how to install jdm maplights....tools-wires...etc.
Old Mar 17, 2003 | 01:52 PM
delsolchic13's Avatar
Default how to install jdm maplights....tools-wires...etc.
bought sum jdm maplights for my delsol....but no
wire or harness jus the lights...hummmm what to do????
[Modified by delsolchic13, 10:52 PM 3/17/2003]
Old Mar 17, 2003 | 09:32 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: how to install jdm maplights....tools-wires...etc. (delsolchic13)
Depending on the sort of connection on the light, probably just a prong that will accept a female connector should work. Then wire it to an existing power source.
It prbably functions and installs similar to a mapliight or dome light would. When I installed a maplight inside the light cover were screws that were used to ground the connection (no ground wire). If there are two separate prongs then verify which is for power (probably red, white/red, or white/green) and which is ground.
Old Mar 17, 2003 | 10:14 PM
krazy's Avatar
check out http://www.hondavision.com , california.teamdelsol.com , http://www.darksol.com , and http://www.teamdelsol.com for how-tos and tips on this.
krazy
hymn
Feb 5, 2014 05:04 AM
swittindoodle
Honda Civic (2001 - 2005)
11
May 3, 2010 09:29 AM
jdmbb6
10
Jul 7, 2005 06:53 PM
tyflip2
May 26, 2004 07:13 AM
everafter
Jan 4, 2004 07:23 PM
