how to install jdm maplights....tools-wires...etc.
bought sum jdm maplights for my delsol....but no
wire or harness jus the lights...hummmm what to do????
[Modified by delsolchic13, 10:52 PM 3/17/2003]
Location: Why so you can pretend like youre interested, FL/OK
Re: how to install jdm maplights....tools-wires...etc. (delsolchic13)
Depending on the sort of connection on the light, probably just a prong that will accept a female connector should work. Then wire it to an existing power source.
It prbably functions and installs similar to a mapliight or dome light would. When I installed a maplight inside the light cover were screws that were used to ground the connection (no ground wire). If there are two separate prongs then verify which is for power (probably red, white/red, or white/green) and which is ground.
krazy
tyflip2
05-26-2004 07:13 AM
