5 bolt vs 4 bolt turbo
hey guys, im looking into buying a Garret T3/To4E 60 Trim, with a .63 A/r Turbine with a stage 3 wheel from http://www.cheapturbos.com. Its only $550, but i realized thats its only a 4 bolt turbo. I was hoping to get the Inline Pro manifold but it only works for 5 bolt turbos. But when i called and talked to stan he said that the 4 bolt turbos are cheap, so he recommended i get a 5 bolt turbo from him, t3/to4e for $899....thats way more. Is there a quality diff in the turbo itself between 5 bolt and 4 bolt? What is a good 4 bolt manifold if i decide to go witht eh 4bolt? I was thinking the NuImage Type-R Manifold. Any experience? thanx guys
Peace
Peace
i went from 5 bolt to 4 bolt only for space issues with my 3" DP. Cheapturbo should be able to upgrade to a 5 bolt for fairly cheap... alot less than $899!!!!
why the HELL are the 4 bolt turbos "cheap"? all they are, are a different housing. i have experience with both manifolds and i would go with the nuimage manifold! its an upgradded meing design and it truly makes power.
just my 2c
just my 2c
yea i didn;t get what he meant by 4 bolt turbos sucked, i figured they were exactly the same right? just diff exhaust bolts for the DP. Im thinking about going with the 4 bolt and then getting the Nuimage Manifold. Both the inline and the nuimage manifold are $600. But i hear there are sometimes some problems with the Nuimage manifold cracking, is this true? I mean i heard the inline manifold lasts FOREVER. But im thinking about 4bolt garret with Nuimage, you guys think the manifold will last? Thanx guys, any experience with either manifold is WELCOME
peace
peace
the 4 bolt exhaust side (also called the ballistic housing) is much better then the old 5 bolt version. It [the ballistic housing] will help spool and turbo efficiency
liam
[Modified by liam821, 2:05 PM 3/17/2003]
liam
i ordered my t304e 50 trim 48 ar from cheapturbo.com for my b16a sol talked to ken super cool guy i have the inline pro manifold so i had to get the 5 bolt it is 50 bucks to convert from 4 to 5 only problem is alot of stuff is on back order
there where some problems with cracking on the old style manifold, but I have seen no problems with any t3t4 e-trims on the nuimage manifolds in the past six months with the new design. there have been nearly twelve of them sold and installed without an issue!
why does it help with spool and efficency? is it just because there is no whole for the internal wastgate to be blocked? please explain! i jst bought a 4 bolt and i would like to know.
i can seriously attest to that statement
hey guys, alright thanx a lot for your help. Looks like i will most likely go for a 4bolt turbo and the nuimage manifold now. That is when i get the money of course. thanx guys
hahah lol
