OT....fuel filter
How's it going guys. I know fuel filter issues have been covered beyond belief but I have one question. Yes I did search and read through everything but I couldn't find out what size wrenches I will need. Am I good to go with a set of regular wrenches and a flare nut wrench? What sizes too? Thanks a bunch.
I believe you need a 10mm for the fuel pressure release bolt, 14mm for the fuel filter bolt and and a 17mm for the banjo bolt. Let me check on that when I get home...
When removing the nut that secures that fuel line, flare wrenches would be good if you have them but the last two times I got the nut loose using some elbow grease w/ just a regular box wrench.
[Modified by Eva01, 9:00 PM 3/17/2003]
calvin924597
May 28, 2010 09:55 PM
