Auto to Manual question
1. i found in the jeg's catalog in the circle track section (no im not a redneck by the way) a clutch pedal kit that comes with:
pedal assembly
master and slave cylinder
all hydro lines
and a "pusher" type piston
can i use this all on a b tranny or at least the pedal and lines? has anyone ever heard of this?
2. for my shifter i found a b&m short shifter for civics and it seems to have the base that the shifter pivots in... can i just blot this base to a sheet of metal and bolt that to the floor and use it?? will i need anything else?
thanx for any help! summer is coming and im in a hurry to get ready
pedal assembly
all hydro lines
What engine are you converting to manual? You will need a manual ECU, possibly the manual throttle body/intake manifold. Don't forget your shift linkage and stabilizer. Probably some mounting issues as well, could require welding.
92lxsleeper
Jul 3, 2009 12:23 PM
