oil coolers: more power and/or more engine life?
Old Mar 16, 2003 | 10:52 PM
accordexchange's Avatar
Default oil coolers: more power and/or more engine life?
i did a search and found one thread on the b&m... i've been looking into the GReddy oil cooler kit... people might say get B&M for the price... i was just wondering if lower oil temperatures will result in power or do they help the engine (and turbo) live longer (kind like tranny coolers)..? also, will i need an oil filter relocation kit with an aftermarket oil cooler or is that something separate..?
"GReddy / GREX Oil Cooler Kits help prolong the life of your engine components and oil. Hard drving causes higher engine temperatures. Factory oil coolers are normally a small water-cooled device sandwiched between the oil filter and engine block. This taxes the cooling system for the engine. GReddy / GREX oil coolers are an excellent alternative. By using a similar inner-fin core design as our famous intercoolers, we are able to increase oil capacity, decrease oil temperatures, and extend engine and oil life. Our systems also offer an internal (or external) thermostat to allow for quick engine warm up. The efficient core and durable steel-braided lines insure good flow and a leak free installation."
Old Mar 16, 2003 | 11:12 PM
Accord94DX's Avatar
Default Re: oil coolers: more power and/or more engine life? (accordexchange)
pictures because i am so goddamn cool:
Old Mar 17, 2003 | 03:37 AM
urbanlegend21's Avatar
New User
Default Re: oil coolers: more power and/or more engine life? (spankey167)
in all reality unless you are running a setup that will increase enigine temps signifigantly or doing road/drag racing where engine temp is a factor then an oil cooler is a waste of money
Honda's can run for 500,000 miles......... what more engine life do you want? do you think you will drive the car to 1 million miles
Old Mar 17, 2003 | 08:50 AM
twkdCD595's Avatar
Default Re: oil coolers: more power and/or more engine life? (urbanlegend21)
I run an extra oil cooler for the added protection when I add some heat to the motor.
I use a nice billet cooler.
Old Mar 17, 2003 | 12:26 PM
Default Re: oil coolers: more power and/or more engine life? (twkdCD595)
Accord94DX, i have to admit-that was pretty badass..!
SOHCArchangel says, "on open deck motors some argue that there is enough thermal exchange between the oil and coolant and all you would need is a lower temp thermostat, and fan switch, but it wont hurt though especially if you are turning higher revs, which is hard to do on a f22/h23, plus extra oil capacity is not a bad thing either..."
urbanlegend21, i was looking for some hidden horsepower but it just seems like most coolers are designed to prolong the life of the parts... my accord is turbocharged and the engine temperatures can get pretty hot... and i was wondering if a reduction in oil temperature will result in any kind of power gains or not... or is just an added safety product..?
Old Mar 17, 2003 | 03:29 PM
iam7head's Avatar
Urbanlegend: I think accordexchange have a boosted monster
you prolly wont benefit from it if you ar NA, mildly modded..
oil cooler are great for boosted car tho
[Modified by iam7head, 12:32 AM 3/18/2003]
Old Mar 17, 2003 | 03:31 PM
iam7head's Avatar
Default Re: oil coolers: more power and/or more engine life? (iam7head)
you dont need a relocation kit as far as i know.
I am getting one as soon as i get my phat check..
accordexchange: grab a tranny cooler for you at if not already
and get a inline filter kit for the ATF
Old Mar 17, 2003 | 04:22 PM
teamlegacy's Avatar
Theres nothing bad about something that will lower temps in the motor. Even if power isn't added, it's a good precaution...
BTW: accordexchange has a EX auto with the DRAG kit last time I checked (HS ownage )
Old Mar 17, 2003 | 04:38 PM
Default Re: oil coolers: more power and/or more engine life? (teamlegacy)
ok ok already-i think everyone already knows what i got under the hood... oh yea, killed a red 88-91 crx w/ integra engine swap (might be my friend's friend) last night on the highway... we raced several times-that was fun...
i guess i'm interested in the GReddy because there isn't a shitload of parts for the accord but GReddy got a specific application for the 5th gen. accords... but i've been advised that if my car isn't currently overheating, then i don't "need" to get it and that normally, engine temp doesnt effect power output... i guess i was thinking that air temp and oil temp were kinda similar...
edit: iam7head, i have the FAL a.k.a. Flex-A-Lite tranny cooler-thanks...
[Modified by accordexchange, 1:40 AM 3/18/2003]
Old Mar 17, 2003 | 04:41 PM
iam7head's Avatar
I think it's more of a extra protection then perfomance gain.
(HS ownage) me too
Old Mar 17, 2003 | 04:43 PM
Accord94DX's Avatar
Yuo crazy guys and your tranny coolers. I'm a paranoid bastard, and I feel for my poor lil oil pump when it has to pump through the turbo AND all those oil cooler lines and stuff....
poor little fella, just sitting there......not knowing whats going on........
*sniffle*
Old Mar 17, 2003 | 04:52 PM
Default Re: oil coolers: more power and/or more engine life? (Accord94DX)
wait a minute-Accord94DX, what oil cooler do you have..?
Old Mar 17, 2003 | 04:57 PM
teamlegacy's Avatar
Who are you Iam7head?
AE: I say go for it. An extra precaution can't hurt anything.
Old Mar 17, 2003 | 05:05 PM
"No matter what kind of oil you use, any type of engine needs a complete lubrication management system. Increased oil temperature will cause a presure drop and decrease the oil's ability to protect your engine. To protect your oil and engine, installation of an oil cooler is necessary. An oil cooler should do more than just cool the oil, but it should be as unrestrictive as possible to prevent a pressure drop across the core. The GReddy Oil Cooler achieves this high flow with the use of high caacity core utilizing an offset internal fin design. "
maybe i should've asked if anyone has an oil cooler on their accord and what kind they running... $100 B&M vs. $400-500 GReddy...... maybe the GReddy is more expensive because of the bolt-on fitment, name brand (jdm bling), stainless hoses, and the thermostat...
Old Mar 17, 2003 | 05:36 PM
Accord94DX's Avatar
I have an HKS oil heater with variable speed exhaust resonator built in.
Old Mar 17, 2003 | 06:51 PM
Old Mar 17, 2003 | 06:57 PM
Accord94DX's Avatar
Old Mar 17, 2003 | 07:04 PM
RotaryBzzz's Avatar
FYI on aftermarket oil coolers....from a Rotary Rx7 perspective (factory engine oil coolers in every car sold). From my understanding, how the aftermarket differentiates from factory mazda is in how the oil circulates within the plumbing. Aftermarkets circulate where you have "geling" of oil layers further from the center and hot oil staying trapped flowing thru the center like this:
C=Most cooled
c=Less cooled
H=Hot
CCCCCC
CccccccC
CcHHHcC
CcHHHcC
CcHHHcC
CccccccC
CCCCCC
Factory Rx7 oil coolers have an internal design that encourages mixing of oil layers so that better cooling takes place:
CHCHCH
CHcHCH
CHcHCH
CHcHCH
CHCHCH
Quote:
The factory (rx7) oil coolers are the best we have ever found for cooling capacity. Virtually all of the aftermarket ones are not even remotely usable
http://www.mazdatrix.com/b6.htm
These guys are hard-core engine builders (mostly SCCA road racing) that are concerned about engine quality, longevity & power...FYI
Old Mar 17, 2003 | 07:06 PM
Accord94DX's Avatar
Default Re: oil coolers: more power and/or more engine life? (RotaryBzzz)
badass tech tip.
Old Mar 17, 2003 | 07:40 PM
iam7head's Avatar
yay or nay?
Old Mar 17, 2003 | 11:48 PM
hey, i thought rx-7s where known for their mad overheating problems..? anyway, time to consider custom rx-7 oil cooler install..?
76 camaro car
Mar 4, 2016 12:27 PM
return_2020
Honda Civic (2001 - 2005)
Sep 2, 2006 06:44 PM
EK45VTi
29
Apr 30, 2004 07:37 AM
Craftyvtec
Jan 8, 2003 06:57 AM
