New pics of my turbo EK4
Old Mar 16, 2003 | 07:27 PM
HYPERTUNE-Mark's Avatar
Default New pics of my turbo EK4
http://www.hypertune.com.au/civic
Old Mar 16, 2003 | 07:28 PM
turbod16y8's Avatar
Default Re: New pics of my turbo EK4 (HYPERTUNE-Mark)
damn thats the biggest intercooler ive seen on a civic....
Old Mar 16, 2003 | 07:31 PM
Jamison's Avatar
Default Re: New pics of my turbo EK4 (turbod16y8)
Who makes that external tach?
Old Mar 16, 2003 | 07:34 PM
Default Re: New pics of my turbo EK4 (Jamison)
All the guages are DEFI. The tach comes in handy when you rev to 10500
Old Mar 16, 2003 | 07:38 PM
AVATAR's Avatar
Thats a pretty killer setup? What are the specs of the motor and turbo.
and yes that intercooler is rediculous
Old Mar 16, 2003 | 07:39 PM
alpha's Avatar
Bad *** Civic! Good luck.
Old Mar 16, 2003 | 07:43 PM
Daniel's Avatar
What are the specs on the motor and turbo? just out of curiousity. . . .
Old Mar 16, 2003 | 07:53 PM
Default Re: New pics of my turbo EK4 (AVATAR)
Specs:
IHI RX6 TCW77 turbo
Motec M4 PRO
Motec CDI
HKS 1000cc Injectors
PLAZMAMAN Intercooler 11.5"x24"x3.5"(Prototype, wait till you see the new one!!)
TODA Camshafts
TODA Valvesprings
TODA Cam Gears
OS Giken Pistons (stock bore)
OS Giken Connecting Rods
OS Giken Twin Plate Clutch
Spoon LSD
Type-R Intake Manifold & TB
Stock B16A Block
Custom made PLAZMAMAN Radiator & Oil Cooler (one piece)
All fabrication by Me and Plazmaman.
Oh, and stock driveshafts. Already broken them once. Any suggestions?
Old Mar 16, 2003 | 07:59 PM
sydag5's Avatar
Those gauges are f**king tight man.
Old Mar 16, 2003 | 08:06 PM
Racerage1's Avatar
sick setup ...maybe i missed it..but how much power are u putting down at the wheels??
[Modified by Racerage1, 9:06 PM 3/16/2003]
Old Mar 16, 2003 | 08:07 PM
avividmemory's Avatar
Default Re: New pics of my turbo EK4 (sydag5)
very nice ride man...lets see some times
Old Mar 16, 2003 | 08:14 PM
alpha's Avatar
Default Re: New pics of my turbo EK4 (SpoolinLS)
428.4WHP
Old Mar 16, 2003 | 08:15 PM
Default Re: New pics of my turbo EK4 (Racerage1)
The power on a Dyno Dynamics dyno is 430 WHP. Another car I did had 250 WHP on a Dyno Dynamics but 318 on a Dynojet.
Dynojet WHP would be somewhere over 500WHP I assume.
I have only raced it once and did 11.5 @ 131 mph. Haven't had time to race it again, but I hope to soon. That pass was the 5th I have done in my life, so obviously I could do with some practise. It spun convincingly in 1st, 2nd & 3rd with the little 22 x 8 x 15 Mickey T's.
Old Mar 16, 2003 | 08:41 PM
boostedsol's Avatar
I think you need a bigger intercooler.
Nice setup bra.
Old Mar 16, 2003 | 08:53 PM
lilxvtecxpwr's Avatar
Default Re: New pics of my turbo EK4 (boostedsol)
damn...i like your gauges. defi is gucci ****...nice
Old Mar 16, 2003 | 09:50 PM
I actually plan on fitting a bigger intercooler. There is a measurable pressure drop with the current Intercooler and I'm sure a better flowing unit would give more power. A friend of mine builds Intercoolers and can get 4" thick tube and fin cores. This will give me better flow and still be lighter than the Bar and Plate core I have now.
Old Mar 16, 2003 | 10:29 PM
VeilSide_Mas's Avatar
do u by any chance have any link with hypertune in Malaysia?
Old Mar 17, 2003 | 12:46 AM
JUNcr-x's Avatar
Default Re: New pics of my turbo EK4 (VeilSide_Mas)
very nice set up! good #'s
Old Mar 17, 2003 | 01:21 AM
Charles B.'s Avatar
Default Re: New pics of my turbo EK4 (b16t4_cr-x)
Siiiiick!! Damn you don't see setups like these that often. Sweet job on the manifold. How's the spool on that turbo? What are the specs on it?
Old Mar 17, 2003 | 01:45 AM
Lei Siew Long's Avatar
Default Re: New pics of my turbo EK4 (SuperDuperEG)
i think i dun jizzed my pants
Old Mar 17, 2003 | 02:56 AM
No link with hypertune in malaysia.
Turbo is an IHI RX6. Ball bearing turbo with 61mm x 82mm compressor can't remember the turbine size but I think the exducer is around 57mm. Turbine is a P22 equivalent A/R is approximately .89.
Spool up isn't too bad but it doesn't really hit hard untill around 6K. I rev it to 10500 so it does have a good power band.
Here is a pic of when I first built the manifold. You can see how the heat has discoloured it.
[Modified by HYPERTUNE-Mark, 11:59 AM 3/17/2003]
[Modified by HYPERTUNE-Mark, 12:01 PM 3/17/2003]
Old Mar 17, 2003 | 03:46 AM
Oh, and if you think my intercooler is big, check this out.....
dfoxengr's Avatar
soooo sexy.....ahhhh drool
Old Mar 17, 2003 | 03:59 AM
alpha's Avatar
Bling Bling
Old Mar 17, 2003 | 04:50 AM
Charlie Moua's Avatar
What toda camshafts are you using and why?
Just curiouse. I'm tyring to build a nice all motor B16 that will be revativly boost friendly with out having to change out anything except for the turbo installation.
