Rotor question(ignition system)
Old Mar 16, 2003 | 07:59 AM
JoshRambo's Avatar
Default Rotor question(ignition system)
I am in the process of putting some new msd stuff in the car and when trying to get to the coil i can't get teh rotor off.
i got the screw out, but the rotor will not budge. is there something i am missing?
fast help would be great.
Old Mar 16, 2003 | 08:16 AM
Bbasso's Avatar
Default Re: Rotor question(ignition system) (Gravity)
I had the same problem, But what I heard on here was Y00 g0t to smash it off- break the plastic rotor then remove the screw.
Does anyone want to confirm what I said?
Old Mar 16, 2003 | 08:18 AM
JoshRambo's Avatar
Default Re: Rotor question(ignition system) (Bbasso)
no way whoudln't have to break it. i thought i was supposed to pop right off.
here it is just comming off
Old Mar 16, 2003 | 08:22 AM
Bbasso's Avatar
My bad i did not read what you typed correctly...
Lightly pry it off, ya know wiggle twist turn... it will pop off just might take a extra min or two since you have the screw out
Old Mar 16, 2003 | 09:35 AM
misledyouth's Avatar
New User
i had one that was seized on. i was prelacing the dizzy any ways but we had to break it off to get the back plastic cover off. I woul djust lightly pry on it and becaareful.
jesse
Old Mar 16, 2003 | 09:36 AM
JoshRambo's Avatar
Default Re: Rotor question(ignition system) (misledyouth)
i got it off i just put a flat head behind it and popped it off.
i was just not pulling hard before.
thanks for the help
Old Mar 16, 2003 | 10:18 AM
py1188's Avatar
Yeah I really had some troble getting that screw off, but not the actual rotor. Glad you got it off though
[Modified by py1188, 1:19 PM 3/16/2003]
Old Jun 25, 2004 | 05:50 PM
Firewerks's Avatar
Default Re: Rotor question(ignition system) (py1188)
what did you guys do to get the screw out? ive tried everything i can think of minus an impact driver... its getting frustrating
Old Jun 25, 2004 | 06:22 PM
uNF$@#!'s Avatar
Default Re: Rotor question(ignition system) (Firewerks)
take the distributor off, as a friend mentioned to me
Old Jun 25, 2004 | 06:24 PM
BlueR's Avatar
Default Re: Rotor question(ignition system) (Captain Commando)
whos gonna set the distributor timing when you put back on?
uNF$@#!'s Avatar
Default Re: Rotor question(ignition system) (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">whos gonna set the distributor timing when you put back on? </TD></TR></TABLE>
you mark it before you pull it off?
Old Jun 25, 2004 | 06:26 PM
BlueR's Avatar
doh! better use a fine point then
Old Jun 25, 2004 | 06:34 PM
uNF$@#!'s Avatar
0.002 finepoint
Old Jun 25, 2004 | 06:36 PM
BlueR's Avatar
all set then
bazoOKA_ TOoth
May 7, 2010 03:28 PM
street_ride14
Mar 21, 2006 05:02 AM
blkgsr03
13
Sep 14, 2005 11:15 AM
SurferX
Jan 24, 2003 08:31 PM
bocian
Feb 20, 2002 06:50 PM
