clutch problem with a B18C1
Old Mar 16, 2003 | 06:19 AM
yellowciv11's Avatar
Default clutch problem with a B18C1
i had a swap done a week ago into my civic. I put a GSR into a 95Civic. Last night i was drving and when i shifted into 4th the clutch stuck and didn't come back up so i pulled it up. Now i can't get it in gear anymore. Any suggestions or reasons why this happened.
Old Mar 16, 2003 | 06:29 AM
IN VTEC's Avatar
Default Re: clutch problem with a B18C1 (yellowciv11)
Failed clutch master or slave cylinder.
Old Mar 16, 2003 | 07:05 AM
94TealGSR's Avatar
You know when you bled the clutch... did you tighten the bleeder valve really tight? If it's just hand tight, you probably worked it loose and shot brake fluid all over the underside of your hood.
If that's not it, you have a failure somewhere, wether its a line or the cylinder.
Old Mar 16, 2003 | 08:46 AM
Default Re: clutch problem with a B18C1 (94TealGSR)
thx for info, ill look in to it.
firecatf7333
Dec 28, 2017 08:14 AM
hannslebo
Mar 24, 2009 01:53 PM
phatsindabuildin
Mar 25, 2008 06:57 PM
xhatchracerx
Aug 31, 2007 01:22 PM
ac_attak
Jun 7, 2006 11:12 AM
