Stock Header Removal
Old Mar 14, 2003 | 04:12 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Stock Header Removal
How do you do it?
I have a civic 89 dx hatch
and i can't disconnect the header from the pipe that connect to the cat because the 3 screws are too hard.
Should I take off the front beam?
Can I take off the front crossmember?
Old Mar 14, 2003 | 04:57 PM
USDM 4G VTEC's Avatar
Default Re: Stock Header Removal (MugenHonda)
put a lot of WD-40 in it....
soak those ****'s
turn the engine on for 3-4 minutes....
apply more WD-40.. be careful and try to loosen them/..
the lil heat will expand the metal a lil and make them easy to loosen...
if u jjust taking the header out bc u got a performance one.... just use a breaker bar..... brake those bolts....
Old Mar 14, 2003 | 05:11 PM
d357r0y's Avatar
you could also heat those bolts with a propane torch and give them a smack with a hammer.
i recently had to CUT them to get the cat off
good luck!
Old Mar 14, 2003 | 05:31 PM
one slow d16's Avatar
Default Re: Stock Header Removal (d357r0y)
I had to use a breakerbar on mine
Old Apr 21, 2006 | 02:54 PM
richboi's Avatar
Default Re: Stock Header Removal (one slow d16)
Yea, i know this post is OLD>>.....but i have a question....wat if ur usin the breaker bar...and the bolts break and gets stuck in the head cyclinder?....so yea.........
Old Apr 21, 2006 | 03:53 PM
YasRex's Avatar
Default Re: Stock Header Removal (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">put a lot of WD-40 in it....
soak those ****'s
if u jjust taking the header out bc u got a performance one.... just use a breaker bar..... brake those bolts....</TD></TR></TABLE>
Use liquid wrench or another pent oil. It works better. Spray, wait about a 10 seconds and whack it with something to make it vibrate. Take a 10 minute break. I used a breaker bar.
Make sure the bar is square on those bolts or you will round them.
JDM_Acccord
Apr 24, 2007 02:00 PM
ophdehEEzY
Mar 5, 2003 09:02 AM
jdmspoonitr
Nov 17, 2002 01:32 PM
iam7head
Nov 2, 2002 04:51 PM
canuckr
Sep 23, 2001 10:59 PM
