Installing a Header Today
Old Sep 23, 2001 | 07:50 AM
canuckr's Avatar
Default Installing a Header Today
Any advice, like how much to tighten certain bolts. I am installing a Spoon 421 header and a test pipe. Thanks for the help.
Old Sep 23, 2001 | 07:58 AM
Rory Breaker's Avatar
Default Re: Installing a Header Today (canuckr)
Spray the cat bolts with wd40.
When removing & tightening the nuts from the head, be very careful not to snap a stud. Its very very easy to do so.
Bring it up from the bottom (common sense).
Clean your fingerprints off of the finish before starting it up for the first time.
Good luck!
Old Sep 23, 2001 | 08:23 AM
mugenr#1011's Avatar
Default Re: Installing a Header Today (newgsrdriver)
let us know how you like it!! good luck
Old Sep 23, 2001 | 08:36 AM
arren123's Avatar
WD-40 helps tremendously.
As for the bolts - they're easy to snap? As long as you don't use excessive force - (60+ lb-ft of torque), you should be ok.
You should add-- bring it up from the bottom and angle it in from the passenger side.. I made the mistake of trying from the driver side (which is impossible without removing a few things). From the passenger side it slips right in
Old Sep 23, 2001 | 09:54 AM
98TypeR's Avatar
Default Re: Installing a Header Today (arren123)
i woudl just remove the fans. it makes life so much easier. and they aren't hard to remove either.
Old Sep 23, 2001 | 10:03 AM
Ibuprofen's Avatar
Default Re: Installing a Header Today (98TypeR)
i'm curious...what tools would u need to install headers? How high does your car need to be raised to remove/install headers?
Old Sep 23, 2001 | 10:08 AM
onyx00's Avatar
Default Re: Installing a Header Today (ITyp3R)
You should have a socket set with a decent number of sizes. That is about it.
In terms of height; when you are installing a header you need to raise the car high enough so that with the header laid on it's size it will fit under the car.
Old Sep 23, 2001 | 10:13 AM
arren123's Avatar
You just need a jack, ramps or jacks stands, and wheel chocks. As for tools, I did mine with a nice 3/8" torque wrench and small extension.
It was tough getting the nuts off of the old manifold. WD-40 is a must. Oh.. and a hammer.
I drove up on ramps (I don't like getting under jackstands unless I have to). The ramps give you plenty of space to work with.
Old Sep 23, 2001 | 11:17 AM
canuckr's Avatar
Thanks for the help, I am taking a break right now cause its raining out and I am working under my car port, so my back is pretty wet. Only one problem, it doesnt seem like my old header wants to come out.
Old Sep 23, 2001 | 11:19 AM
arren123's Avatar
Did you take off the bracket on the side? Also, you'll need to separate the top and bottom piece before you can pull it out.
Old Sep 23, 2001 | 11:25 AM
canuckr's Avatar
its just one bolt on the right side, right, i got that one. Its lose up top where it bolts up but not where that bracket is, is there another bolt?
Old Sep 23, 2001 | 11:32 AM
arren123's Avatar
I know there were two bolts on the side. I think I took both of them out to make sure that it'll come out. I think you only need to remove one though.
The only other thing holding it on would be the bracket right before the cat.....
Old Sep 23, 2001 | 11:41 AM
MintyDip's Avatar
i have a how to header on my site... http://mintydip.homestead.com/
I think it will help you out alot on the install.
check it out before sept 30.....they are shutting my site down
Ill move it after ti gets shut.....
[Modified by MintyDip, 12:41 PM 9/23/2001]
Old Sep 23, 2001 | 01:52 PM
disordeR's Avatar
Default Re: Installing a Header Today (MintyDip)
mintydip, looked through your "how to's". very nice and informative. i hope to refer to your page when i get my headers, cat, and exhaust.
Old Sep 23, 2001 | 10:59 PM
MintyDip's Avatar
Default Re: Installing a Header Today (addicted2VTEC)
hehe thx
i will be moving my site soon, but just come to the same link, and ill link it to my new place
blackccoupe
Sep 23, 2010 08:13 PM
Zulu888
Jun 16, 2006 05:49 PM
MugenHonda
Apr 21, 2006 03:53 PM
AGENT 99
Dec 4, 2004 02:37 PM
ophdehEEzY
Mar 5, 2003 09:02 AM
