Mechanic Advice: Overheating only during idle suggestions needed
Old Mar 14, 2003 | 11:43 AM
IdotheSHOCKER's Avatar
Default Mechanic Advice: Overheating only during idle suggestions needed
Scenario: D16y7 engine.
Car overheats when sitting in traffic for a long time and with the AC on of course, turning off the AC helps but the water gauge still rises up past the middle level.
Changed the thermostat but after driving for a week the problem occurs again.
I do a lot of highway driving and there is no problem with overheating on highway speeds its just while sitting idle.
Im gonna do the waterpump this weekend, any other suggestions?? Maybe head gasket??
Thanks.
Old Mar 14, 2003 | 11:46 AM
IM ALL BOB's Avatar
Default Re: Mechanic Advice: Overheating only during idle suggestions needed (EGB18hatch)
had the same problem with my d16y7... but I ended up swapping it out like 3months later.. never did quit figure out what the problem was...and I changed the theremostat..radiator car..checked fan switch.. everything was a okay.. it was probably a leaky headgasket or something since my coolant would dissapear with no visual signs of leakage
Old Mar 14, 2003 | 11:47 AM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
does your fan work
Old Mar 14, 2003 | 11:48 AM
Kamin's Avatar
Default Re: Mechanic Advice: Overheating only during idle suggestions needed (CiRcUiTsi)
if the fan DOSENT work
it could be (most likley) the coolant temp sensor.
if it DOES work it could be your radiator.
Old Mar 14, 2003 | 12:11 PM
Default Re: Mechanic Advice: Overheating only during idle suggestions needed (Kamin)
Fan works....
Radiator doesnt really show signs of a leak as of yet.
Old Mar 14, 2003 | 02:20 PM
aw1234dude's Avatar
you probably have an air bubble somewhere in your coolant lines. Try bleeding your coolant lines and see if that solves the problem.
Old Mar 14, 2003 | 03:13 PM
timmo's Avatar
Default Re: Mechanic Advice: Overheating only during idle suggestions needed (aw1234dude)
Hows the radiator fluid level? Do you have to constantly refill it?? Monitor that if you haven't already.
If that is the case then you probably have a leak somewhere and if there is no visible signs of fluid leak (like small puddles under the car after being parked over night) then its probably the head gasket.
I would also suggest a complete flush of the system. Could be some build up somewhere thats preventing the radiator fluid from flowing properly.
Good Luck!!
Old Mar 14, 2003 | 04:05 PM
Dr. EKology's Avatar
Once the engine starts warming up try touching the radiator hoses (top and bottom) to see if both of them are hot. That info would help too.
Old Mar 14, 2003 | 04:17 PM
Westsideboy's Avatar
Default Re: Mechanic Advice: Overheating only during idle suggestions needed (EKology)
My first obvious check would be your water pump. Have you checked that? How many clicks you have on the engine? 100+?
adobospoon
May 31, 2014 06:05 AM
PaulMc
Feb 20, 2014 09:43 PM
denracho
Dec 31, 2009 10:45 PM
Integra Integra
Dec 15, 2005 06:15 AM
