Exhaust Rattle #30240
Old Mar 14, 2003 | 11:37 AM
vtec.dc2's Avatar
Default Exhaust Rattle #30240
I have jdm4-1 header/carsound cat. Previosly I had a rattle issue with the cat (heatshield) - 2 metal hose clamps took care of that.
Right now i have 3-4rpm rattle. Donut gasket between header/cat is black. Could this cause rattle?
Old Mar 14, 2003 | 11:43 AM
mstewar's Avatar
Default Re: Exhaust Rattle #30240 (vtec.dc2)
the catalyst in your carsound cat is probably loose.. welcome to the world of running carsound cats in untuned ITRs.. running very rich burns them out..
there's a lot of info available on this if you search..
Old Mar 14, 2003 | 11:47 AM
vtec.dc2's Avatar
Default Re: Exhaust Rattle #30240 (mstewar)
my car is tuned.. and i cat seems fine when you look through. but... could bad donut gasket cause the rattle?
Old Mar 14, 2003 | 11:51 AM
The Toecutter's Avatar
The rattle you mention is most likely the catalyst. Those things are not the best-built converters.
Old Mar 14, 2003 | 11:57 AM
vtec.dc2's Avatar
Default Re: Exhaust Rattle #30240 (Velocity)
thanks, the rattle doesn't start until the car warms up, cat has 40K on it.. - when tapping/shaking cat around, nothing feels loose..
can anyone answer my other question. - can bad donut gasket cause rattle?
Old Mar 14, 2003 | 02:57 PM
tecnic1's Avatar
I had the same problem, so I just took my whole b=pipe/cat off and had a 2.5 inch header back b-pipe made. Either the rattle went away, or I can't hear it over my bumblebee on crack annoying exhaust tone.
Old Mar 14, 2003 | 07:37 PM
done's Avatar
tighten the bolts..
Old Mar 14, 2003 | 07:42 PM
gsrvx's Avatar
New User
Default Re: Exhaust Rattle #30240 (Jordo)
My carsound rattled just like u described. Later found out that it gutted itself
Old Mar 14, 2003 | 07:55 PM
Tweakmeister's Avatar
Default Re: Exhaust Rattle #30240 (RK)
if you're still running the stock exhaust then check the heatshielding welded to the piping. I had to use a clamp around it.
Old Mar 14, 2003 | 08:05 PM
CWESTINAP1's Avatar
usdm cat is not 2.5 inches so it will cause the heatshield to rattle.
AZNracerx1989
Apr 18, 2023 05:30 AM
GothicTuner
Mar 26, 2003 12:41 PM
GothicTuner
Mar 26, 2003 11:51 AM
