change brakes and cars shakes a lot.....
Old Mar 14, 2003 | 11:18 AM
brega3's Avatar
Default change brakes and cars shakes a lot.....
Hey fellas I just changed my rotors and pads front wheel and the car shakes a lot everytime I brake hard when I am going fast. Any ideas what could be the problem? any help will be appreciated.
Old Mar 14, 2003 | 11:21 AM
Perfectionist's Avatar
Default Re: change brakes and cars shakes a lot..... (brega3)
Good possibility your rotors aren't true or you've got an oily spot on them.
Old Mar 14, 2003 | 12:24 PM
97accordex's Avatar
Default Re: change brakes and cars shakes a lot..... (Perfectionist)
Probably high spots on rotors. They should wear down eventually. Usually its takes a while for pads to seat properly too.
Old Mar 14, 2003 | 12:30 PM
Crono139's Avatar
What brand are they?
Old Mar 14, 2003 | 12:43 PM
brega3's Avatar
Default Re: change brakes and cars shakes a lot..... (Crono139)
so should I wait a little and see if they set right? and the rotor I bought at pet boys. and I also clean the rotors with a brake cleaner. So I don't know what is wrong.
Old Mar 14, 2003 | 01:00 PM
JimBlake's Avatar
Did you clean the hub surface where the rotor mounts? A piece of crud under the rotor will make it wobble.
Did you overtighten your lug nuts? That could warp your rotors.
I was trying to figure out how to ask if you cleaned off all that greasy crud that always comes on new rotors... Good thing you already did that.
Old Mar 14, 2003 | 01:06 PM
brega3's Avatar
Default Re: change brakes and cars shakes a lot..... (JimBlake)
I don't think I overtight the lugs but if I would loosen then up a little would that solve the problem if in any case I did overtight them?
Old Mar 14, 2003 | 03:10 PM
TypeSH's Avatar
loosen and then retorque to spec... you dont want your lug nuts falling off now...
Old Mar 14, 2003 | 03:43 PM
krzyaccord's Avatar
Default Re: change brakes and cars shakes a lot..... (TypeSH)
If you still have a problem, try using a on-car brake lathe. Sometimes even new rotors aren't true.
Old Mar 15, 2003 | 02:36 PM
brega3's Avatar
hey guys I ended up resurfacing the danm rotors today and now they are working fine... Thanks for all the input....
91b16acrx
Jan 28, 2008 11:22 AM
poppypizza
27
Apr 23, 2007 04:09 PM
civic91
Apr 2, 2003 01:23 PM
TsunamiZC
Jul 23, 2002 11:51 AM
Tom Clancy
Mar 29, 2002 08:58 AM
