car isnt starting
Old Mar 13, 2003 | 06:23 PM
DeNtEd91HaTcH's Avatar
Default car isnt starting
i have a 91 civic hatch back and just the other day my car wouldnt start wouldnt turn over or anything, so i bought a new starter because the i had this same problem before but i put in the new starter and it still wont turn on.... anyone know what it might be? thanks
Old Mar 13, 2003 | 06:26 PM
BauleyCivic's Avatar
Risky Business
Default Re: car isnt starting (DeNtEd91HaTcH)
Probably the battery...
Old Mar 14, 2003 | 05:07 AM
Red94Sedan's Avatar
Default Re: car isnt starting (BauleyCivic)
What BauleyCivic said...
Instead of buying a new starter go buy a Battery.
Old Mar 14, 2003 | 05:24 AM
Noe Kozz's Avatar
Default Re: car isnt starting (Simple 4dR)
Before you go run out and buy a battery, did you check if you have any spark at all? Do you hear the fuel pump when you turn over? Does the car turn over at all? Get a jump from someone and see if your car turns on, if it doesn't, then it's not the battery. Don't just go waste your money on something you don't really need. Check your distributor, alternator, etc if the car doesn't start with a jump.
Old Mar 14, 2003 | 06:59 AM
NaughtyKnight666's Avatar
my 94 coupe would not start the other day either but before just replacing parts i took a look at it turns out i just needed to adjust the sensor that tells the clutch is in. it could always be somthing stupid so just take u time and look at everthing that makes a car start and u will find ur problem.
EGHondalover88
31
Jan 18, 2010 03:26 PM
SwiftTypeR
Jan 3, 2008 06:46 AM
Legendaryyaj
Mar 8, 2007 01:41 PM
DC2_ALL MOTA
Oct 10, 2006 01:31 PM
KloC 95 EG
Dec 9, 2005 02:16 AM
