skunk2 camber kit?
Old Mar 13, 2003 | 06:14 PM
Phoenix_ITR's Avatar
Default skunk2 camber kit?
my friend and i just started our install on my skunk2 camber kit and we ran into some problems. the box said 96-00 civic and the control arms do not look like the ones we pulled off of my car. are the UCAs for the civic the same as the ones for the DC2? any help is appreciated. also, if possible, could you post pics of what the skunk2 UCA for the teg look like? thanks a lot...
-tony
Old Mar 13, 2003 | 06:58 PM
Default Re: skunk2 camber kit? (delinquent)
well...after looking at both pieces, i've already determined that they are definitely not going to work. massimo performance accidentally sent me the wrong kit. hopefully i can get this resolved easily...
-tony
Old Mar 13, 2003 | 07:08 PM
Eric R's Avatar
The arms are not the same.
Old Mar 13, 2003 | 07:10 PM
whtdc2's Avatar
New User
mine looks klike this I had mine off as those 4 holes didn't line up, I think Shunk2 camber kits are ****
[Modified by whtdc2, 2:11 PM 3/14/2003]
[Modified by whtdc2, 2:12 PM 3/14/2003]
Old Mar 13, 2003 | 07:16 PM
SpoonEK2's Avatar
Default Re: skunk2 camber kit? (whtdc2)
what happened to your bushings? there are gone...
Doesn't skunk2 use OEM arms as a base and change the ball joint area?
Old Mar 13, 2003 | 07:21 PM
whtdc2's Avatar
New User
Default Re: skunk2 camber kit? (SpoonEK2)
They came as it is
Old Mar 13, 2003 | 07:26 PM
migs's Avatar
You use your OEM bushings. Skunk kit comes as you see in that picture, even with the dirt.
Old Mar 13, 2003 | 07:40 PM
SpoonEK2's Avatar
Default Re: skunk2 camber kit? (Migs)
oops...was comparing them to EK arms...
Old Mar 13, 2003 | 07:50 PM
Denny's Avatar
if you have the skunk2 part#:516-05-0670
they fit:
92-95 Civic, Delsol
94-01 Integra
They dont come with the bushings, you are supposed to use the OEM ones. The ones you pictured looks like mine. should fit. hope this helps
Old Mar 13, 2003 | 08:55 PM
tC_Dragon's Avatar
Default Re: skunk2 camber kit? (TypeR882)
yup massimo sent u the wrong ones then.... sorrie to hear that bro..
Old Mar 14, 2003 | 12:46 AM
Default Re: skunk2 camber kit? (pdcdragon)
i'll call tomorrow...hopefully it can be sorted out before my next track event.
<<edit>> just wanted to thank everyone for their help.
-tony
[Modified by delinquent, 9:47 AM 3/14/2003]
Old Mar 14, 2003 | 04:23 AM
Albino Dragon's Avatar
I am curious as to why you guys think the Skunk2 pieces are such pieces
Albino who just ordered his skunk pieces on monday...
Old Mar 14, 2003 | 07:48 AM
26R's Avatar
26R
Default Re: skunk2 camber kit? (Albino Dragon)
I have the skunk2 camber kit on my GSR, no problems at all and I don't think its a piece at all.
Old Mar 14, 2003 | 08:23 AM
Jowee's Avatar
Default Re: skunk2 camber kit? (SkunkdGS-R)
Im sure Nick will fix the problem. He's a really cool guy to do business with. to Nick.
Old Mar 14, 2003 | 09:00 AM
Jet Phi's Avatar
Default Re: skunk2 camber kit? (ITR 98 1162)
nick is the man . . .
they were sent out on moday the 10th and i recieved them on wensday the 12th
i got it on my 99 si installing it soon
Old Mar 14, 2003 | 01:24 PM
tC_Dragon's Avatar
send me an IM if you have any more questions bout install when u get the right one...
Old Mar 14, 2003 | 11:11 PM
thanks a lot -- i'll keep that in mind.
-tony
cookieboy87
May 2, 2008 01:44 AM
lsvtec_hatchback
Suspension & Brakes
Jan 19, 2007 06:00 PM
BoOsTiN Dc2
Suspension & Brakes
Sep 8, 2005 04:49 AM
rad_thundercat
Mar 18, 2005 03:28 PM
