G2 Revving Problem?
Hi I had recently just purchased a 1990 Acura Integra LS and when I started the car it starts revving itself like when you start it just starts revving from 1,000 to 3,000rpm I was wondering what could be wrong can someone plz help me.
Thanx in advanced. Matt
Could be many things. Here are what you should check for.....
1. IAC (Idle Air Control)
2. Check for any Vacuum Leaks
3. Intake Manifold gasket could have a leak which could cause a vacuum leak.
Most likely it's a Vacuum leak so check every single vacuum line to make sure you don't have a leak anywhere.
honcrf150
13
May 29, 2012 10:28 AM
