Interesting header design
I think that it has too many bends, which will impede flow to a certain extent...also any concerns with that much heat by your tie rod ends, back side of the brakes, cv boots...
probably routed it that way for maximum ground clearance - other than that I agree with Austin's comments
[Modified by Big Phat R, 10:42 AM 3/13/2003]
That sharp 90 degree bend just after the collector, can't be a good thing.
If you want that extreme of a header, just run a side exit exhaust.
hybridpatient95
14
May 1, 2005 02:52 PM
