z6 swap in 94 dx hatch everything but vtec will work right??
Old Mar 12, 2003 | 09:00 PM
jdm169's Avatar
Default z6 swap in 94 dx hatch everything but vtec will work right??
this is for a friend, were gonna swap a z6 sohc vtec in his dx hatch. From what i understand everything will be a direct swap right? The car will run right, but no vtec. Is there a ghetto way to get vtec on for now, like hooking up to switch or something... anything to look for, thanks so much
Old Mar 12, 2003 | 09:30 PM
B19CivicHB's Avatar
Default Re: z6 swap in 94 dx hatch everything but vtec will work right?? (jdm169)
That is correct. Use the z6 wiring harness. Run a wire from D3 on the ecu to the VTEC solenoid. More detailed info at http://www.hybridgarage.com
-Nick-
Old Mar 12, 2003 | 10:37 PM
jdm169's Avatar
Default Re: z6 swap in 94 dx hatch everything but vtec will work right?? (B19CivicHB)
so the car wont run with the dx harness, si harness is the only way??
Old Mar 12, 2003 | 10:49 PM
jdm169's Avatar
anyone?
Old Mar 12, 2003 | 11:03 PM
norcalcrx's Avatar
It will work but you will need to wire the vtec sol. and the vtec pressure switch. Also the power and signal wire for the Evap purge sol.
http://hybrid2.honda-perf.org/tech/info.html#B18EG6 here is a link to help
Old Mar 12, 2003 | 11:06 PM
jdm169's Avatar
Default Re: z6 swap in 94 dx hatch everything but vtec will work right?? (norcalcrx)
will the car still run though without these wires but no vtec??is that right
Old Mar 12, 2003 | 11:58 PM
RICE POLICE SIP's Avatar
ok if you want this to be about as easy as possible then... if the z6 comes with the wire harness then GOOD but if it doesn't then find one and use it... everything plugs in... then you'll have to run two wires FROM the ECU TO the HARNESS... the two wires you will have to run, IF you follow the wire harness is the GREEN W/ YELLOW stripe (vtec solenoid) to A4 in the ecu pressure switch) to D6 (there is no wire there right now, you have to put one there) and that should be it.....
Old Mar 13, 2003 | 05:22 PM
jdm169's Avatar
Default Re: z6 swap in 94 dx hatch everything but vtec will work right?? (92boostn'hatch)
thanks that's what i needed
Old Mar 13, 2003 | 05:39 PM
no prob
michaelsej1
Aug 27, 2010 06:43 AM
TeamRPM_ZC
Jul 14, 2008 08:36 AM
jjyynnxx
Aug 10, 2006 09:06 AM
hatchback_al
May 31, 2004 03:05 AM
Azntwins
Mar 8, 2004 12:08 PM
