valve adjustments
Old Mar 12, 2003 | 08:06 PM
HuskerHybrid's Avatar
Default valve adjustments
i've heard tegs are notorious for valve clicking, and i just noticed mine doing it, is it worth the money to have them readjusted? or will they just go out of spec again right away? besides the noise are there any bad/negative problems from this?
Old Mar 12, 2003 | 08:32 PM
mr.beeks's Avatar
Default Re: valve adjustments (HuskerHybrid)
well valve adjustments should be performed after
a certain mileage
whats your mileage and what kind of oil are you using..
Old Mar 12, 2003 | 08:35 PM
Default Re: valve adjustments (FRANCISCO FLORES)
using valvoline dino, it's at about 85k...
a certain mileage
Old Mar 12, 2003 | 08:36 PM
mr.beeks's Avatar
OK
what grade oil
and when was the last time the valves got adjusted??
Old Mar 12, 2003 | 08:39 PM
10w-30, every 3k
Old Mar 12, 2003 | 08:40 PM
Rtzx9r's Avatar
GDD 1%
oil and it's viscosity have nothing to do w/ when to adjust valves. (It may have some effect on ticking noise, but thats cosmetic)
Valve adjustments need to be done EVERY 30K and they are really easy on b18b and you need a snap on tool for VTEC tegs.
Get a Helms and do it yourself- it is EZ. (Dealers want ~100, helms is 70)
Edit- you'll see an increase in MPG and performance as well after doing them, and the noise will go away.
[Modified by Rtzx9r, 5:41 AM 3/13/2003]
Old Mar 12, 2003 | 09:04 PM
ITR 01-0422's Avatar
my bro just had his valves adjusted and the car is at 35k. you might want to get it adjusted cause it might get worse.
Old Mar 12, 2003 | 09:14 PM
Default Re: valve adjustments (ITR 01-0422)
my gas mileage has been horrible lately and i couldn't figure out why, i thought it was maybe from the cold
Old Mar 12, 2003 | 09:23 PM
ALF's Avatar
ALF
You shouldn't go by any specific intervals when doing a valve adjustment. If you hear them ticking, you need one...if there's no ticking, no need. You'll need an adjustment more often if you linger in the higher RPM range often. I do mine anywhere from every 10k to 20k miles depending on how I drive.
Learn to do it yourself and you'll save lots of money. It's easy with the right tools.
If you need to pay someone to adjust them for you, go ahead. If you want to adjust them less often, simply stay away from the higher RPM range.
rondogg779
Oct 28, 2019 11:19 PM
Jhicks
Feb 3, 2012 05:58 AM
Petah
Honda Civic (2001 - 2005)
Apr 26, 2007 03:07 AM
user 98292739
Apr 17, 2005 08:22 PM
Lowez
May 19, 2002 04:00 PM
