Turn A/c on no air comes out...
Old Mar 12, 2003 | 03:53 PM
joy ride's Avatar
Default Turn A/c on no air comes out...
I went to use the A/C ;push the button to activate ac;turn the *** to high and no air comes out of the events at all;tried low; still no air...I can hear the A/c compressor kick on...Checked all fuses all seem to be in good working order...does this sound like my heater blower motor is out...if so were exactly is is located...any help appreciated...
Old Mar 12, 2003 | 05:06 PM
aznmc16's Avatar
Default Re: Turn A/c on no air comes out... (joy ride)
the heater blower motor is located right under the passenger side foot area.
just put your headunder there, you'll see a white circular thing.. it has 3 screws. just unscrew it.. unplug it.. and there you go.
very easy to change.
Old Mar 12, 2003 | 05:51 PM
97gSrkId88's Avatar
ya i found a dead mouse in one of the custumers car once it was funny......lol
then i got hungry
Old Mar 12, 2003 | 06:02 PM
GTlvr82's Avatar
check for any vacume hoses that are disconnected I know I had that problem and couldn't figure out what was wrong, and I found the vacume hose and that fixed it.
Old Mar 13, 2003 | 09:30 AM
joy ride's Avatar
Default Re: Turn A/c on no air comes out... (GTlvr82)
Well i check lead to the motor which showed the switch is working...verified the motor is shot...Problem theres apparently not enough room to pull the motor assebly out right? I tried and tried and still couldnt get it out...looks almost I might need to remove the dash to get to it all ....correct or not thanks once again...
Old Mar 13, 2003 | 11:10 AM
1320b4u's Avatar
A/c is for the weak
Old Mar 13, 2003 | 12:15 PM
joy ride's Avatar
Default Re: Turn A/c on no air comes out... (1320b4u)
blow me...i live in West tex...we just barely did away w/horses 2 years ago...Or so Ya'll think
Old Mar 13, 2003 | 04:37 PM
joy ride's Avatar
Anybody else...thanks...
Old Mar 13, 2003 | 07:55 PM
PnX-R's Avatar
I don't get it.. You check lead to the motor which showed the switch is working??..
Old Mar 13, 2003 | 08:02 PM
DA MUGEN 1's Avatar
Default Re: Turn A/c on no air comes out... (aznmc16)
Exactly what he said trust me I use to be a Honda Tech that worked in Arizona one of the hottest states
lphthephunk
Aug 9, 2014 05:49 AM
Krivsky
Aug 8, 2013 04:17 AM
ClarkRU
Jan 17, 2011 09:53 AM
dabflyboy
Jul 3, 2009 03:18 PM
BrenaNickels
Aug 24, 2008 06:10 PM
