Maxrev BOV sound?
Old Mar 12, 2003 | 03:35 PM
buh_buh's Avatar
Default Maxrev BOV sound?
I'm currently using the Maxrev BOV (came with the Maxrev kit), and I can BARELY hear the BOV when driving. Is this normal? I can only hear it when I'm trying to listen for it, and when I do hear it, its a slight flutter. Can anyone help?
Old Mar 12, 2003 | 10:03 PM
buh_buh's Avatar
Default Re: Maxrev BOV sound? (buh_buh)
nobody? it doesn't really sound like its opening up.
Old Mar 12, 2003 | 10:09 PM
Full-Race Javier's Avatar
i had one on my car (nissan 1.6L) with a small T25/T3@6psi it had a nice sound to it. even gassing it in neutral/no load, it would "blowoff" it sounds good.
is it opening at all? hear any surge?
Old Mar 12, 2003 | 10:15 PM
buh_buh's Avatar
Default Re: Maxrev BOV sound? (javierb14)
I know its opening for sure, but I just hear a slight flutter. And its only if I'm trying to listen for it. Maybe it needs to be "broken in"?
Old Mar 12, 2003 | 10:23 PM
you can adjust the preload on the spring by turning the cap clockwise or counterclockwise....maybe that'll help. or u could try a different vacuum source. another option might be to order a different spring rate for the valve. it doesnt need breaking in, the piston and cylinder are machined out of dissimilar metals, they help prevent sticking.
Old Mar 12, 2003 | 10:28 PM
b18cya's Avatar
the fluttering you arae hearing is probably the wastegate. thats exactly how i would describe the sound of my tial WG
Old Mar 13, 2003 | 04:52 PM
buh_buh's Avatar
Default Re: Maxrev BOV sound? (b18cya)
so if its my wastegate going off, then my blowoff valve isn't blowing off at all then? I've never heard of a wastegate making a noise like that
Old Mar 13, 2003 | 05:53 PM
johnisenglish's Avatar
Are you sure that fluttering isn't compressor surge? You might want to check your vacuum lines if that's the case
Old Mar 13, 2003 | 06:00 PM
yellowhonda88's Avatar
Default Re: Maxrev BOV sound? (johnisenglish)
well, they dont need to be broken in and if it was not working properly there would be compressor surge. If you are here a flutter like a fast "woooowooowooop" noise then the BOV is too tight and letting the air back up.
Brett
Old Mar 13, 2003 | 07:42 PM
buh_buh's Avatar
Default Re: Maxrev BOV sound? (yellowhonda88)
how do i adjust the bov? just turn the top part where the line is attached to? Cuz I turned it a couple times, but no change in bov sound
[Modified by buh_buh, 9:43 PM 3/13/2003]
Jkan2001
Oct 2, 2002 04:39 PM
