Greddy e-manage for Turbo R
Old Mar 12, 2003 | 02:40 PM
GettaluvR's Avatar
New User
Default Geddy e-manage for Turbo R
i'm thinking buy a emanage for my turbo R, what do you guys think, should i use AEM EMS or e-manage, which one would be better.
also just wonder if i just the e-manage do i still need FMU and Inline fuel pump also VAFC ?
i'll be running only 4.5psi. what do u think, should i go with e-manage or just leave it with vafc, fmu and fuel pump ?
tahnks
also deos anyone has experience with the e-manage ?
Old Mar 12, 2003 | 02:42 PM
Reid's Avatar
Global Moderator
Default Re: Geddy e-manage for Turbo R (GettaluvR)
Get whatever system you can tune better.
Ditch the stock injectors, FMU, and V-AFC and get some 550s.
Old Mar 12, 2003 | 02:55 PM
SurferX's Avatar
The E-manage is just a piggyback like the VAFC, tricks the ECU by telling to go to different portions of it's stock map. It's not a full blown ECU reprogramming system.
Old Mar 12, 2003 | 02:57 PM
Reid's Avatar
Global Moderator
Default Re: Geddy e-manage for Turbo R (SurferX)
For this reason, I was going to suggest the AEM at first.
Then I realized that if he can't make use of the AEM unit, he's better off with the Greddy.
Old Mar 12, 2003 | 03:01 PM
sgT's Avatar
sgT
Default Re: Geddy e-manage for Turbo R (Reid)
imo the greddy interface will be just as confusing
Old Mar 12, 2003 | 03:02 PM
Reid's Avatar
Global Moderator
Default Re: Geddy e-manage for Turbo R (sgT)
This is true.
But there must be a reason why he's narrowed down his choices to these two.
Old Mar 12, 2003 | 03:07 PM
sgT's Avatar
sgT
misinformation?
Reid's Avatar
Global Moderator
misinformation?
But I read it on Honda-Tech...
Old Mar 12, 2003 | 03:08 PM
sgT's Avatar
sgT
well, you read it, so it must be true....
Time to sell the hondata.
Old Mar 12, 2003 | 03:20 PM
Denny's Avatar
get the emanage and the e-01 (i think thats what is called) the emange is a lot better than a vafc. All shops i have gone too have recommended the e-manage over ther vafc
Old Mar 12, 2003 | 03:29 PM
GettaluvR's Avatar
New User
what else can i use ?
last time i post people told me just with FMU (from drag kit) it will run too rich, so i called some shop, they told me i can use ems or e-manage, since they cant tune hondata so hondata is out of question.
so you guys are saying e-manage is just same as vafc ?
is there any other way to make my R safe ?
Old Mar 12, 2003 | 03:35 PM
Reid's Avatar
Global Moderator
If the shop can tune the EMS, get that.
Old Mar 12, 2003 | 04:25 PM
Denny's Avatar
The VAFC doesnt even compare to the E-manage. E-manage is 16 point curve while the VAFC is 8 point, you do the math
Old Mar 12, 2003 | 04:33 PM
mstewar's Avatar
Default Re: Geddy e-manage for Turbo R (TypeR882)
That's twice as many points.. i'm smart..
seriously, what made you pare the list of choices down to those two?
Old Mar 12, 2003 | 06:22 PM
GettaluvR's Avatar
New User
Default Re: Geddy e-manage for Turbo R (mstewar)
so is there anything else i can get except ems and e-manage
Old Mar 12, 2003 | 06:35 PM
GettaluvR's Avatar
New User
if it;s just vafc and e-manage
which one would u guys perfer
Old Mar 12, 2003 | 07:11 PM
vtec.dc2's Avatar
https://honda-tech.com/zerothread?id=350683 - there are other systems out there - some won't be as cheap.. as mentioned earlier in the thread - your setup will only be as good as you get it tuned. So, if you theres a better shop even 3-5 hours away, its worth the travel.
browse arvhives in FI forum - covers most if not all of systems.
Old Mar 12, 2003 | 07:16 PM
MiraiZ's Avatar
My advice is to get the one that has the bst support in your area...I would have gotten a Hondata, but aside from Sgt's occasional trip to JDM land, I would have no support for it locally. So I wound up getting an Apex PFC...tons of support here for this.
[Modified by MiraiZ, 1:16 PM 3/13/2003]
Old Mar 12, 2003 | 08:44 PM
mstewar's Avatar
AEM EMS, Greddy eManage, Hondata, Apex PowerFC, Apexi VAFC.. there's probably a few more, but that's off the top of my head..
Old Mar 12, 2003 | 10:18 PM
spoonek4's Avatar
Can't compare. V-AFC have wayyyyyy less potential IMO.
There are other choices like HKS F-con series? That HKS and JUN uses those to setup cars.
Old Mar 26, 2003 | 02:45 PM
NeXtLeVeL_TyPe_R's Avatar
Hey GettaluvR,
I am going to be installing The Greddy Emanage in my turbo type r very soon.
I have some other stuff to do also but i will probably be done in a month i will let you know how it goes
I am going to use all the harness like boost and ingnition plus i am giong to try the 2 additional injector setup also so hopefully all goes well
i will check back wit ya
Old Mar 26, 2003 | 03:19 PM
GettaluvR's Avatar
New User
Default Re: Geddy e-manage for Turbo R (NeXtLeVeL_TyPe_R)
please keep us update with ur R
DIRTYsouthBB6
May 9, 2006 05:10 PM
JDM 93 EJ1
Jan 20, 2005 09:43 AM
boosted lude
Nov 3, 2004 08:05 AM
RCSIVTEC
Apr 26, 2002 10:30 AM
sagaprelude
Feb 5, 2002 01:16 PM
