a question how much should you retard your timing
Old Mar 12, 2003 | 02:07 PM
silver4's Avatar
Default a question how much should you retard your timing
how much should you retard your timing on a d16(if that matters) running a 50 shot?
what are the best ways of doing that?
is it easy or hard?
Old Mar 12, 2003 | 02:14 PM
kyle h.'s Avatar
Default Re: a question how much should you retard your timing (silver4)
best way = MSD BTM
easiest way = turn your distributor towards the headlights, using a timing gun.
50 shot timing retard degrees should be listed in the kit instructions, i'm not sure if you are supposed to retard on a 50 shot.
Old Mar 12, 2003 | 03:24 PM
mannyman's Avatar
El Veterano de Sur Califas
Default Re: a question how much should you retard your timing (kyle h.)
yeah..i wouldnt retard on a 50 shot. it actually is worst to retard the timing on a small shot like that. They make it so u can use a 50 shot on a stock engine.
IemSpooled219
May 13, 2009 02:57 PM
Tippyman
Nov 22, 2005 09:11 PM
dimotorsports
Mar 22, 2004 07:14 PM
SOHC_MShue
Nov 30, 2003 07:54 PM
redteg1
Jan 23, 2002 06:00 AM
