Challenges of turboing an OBDII integra?
Old Mar 12, 2003 | 07:59 AM
ski_rebel_3's Avatar
Default Challenges of turboing an OBDII integra?
What are the challenges of turboing an OBDII integra? My 95 GSR was stolen so now I have to start over. I have been looking for a good 94-95 GSR but have not had much luck so far. I have found a ton of 96-up but they are all OBDII's.
So my question is should I just keep looking for a 94-95 or just give up and get a 96-up GSR?? I know that OBDII's can be a pain in the *** sometimes so basically I want to find out if I have to go 96-up what kind of issues should I anticipate?
Old Mar 12, 2003 | 08:01 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Challenges of turboing an OBDII integra? (ski_rebel_3)
This is the new century where ob1 or 2 doesnt really matter anymore. I have obd2 and Ive been fine.
Old Mar 12, 2003 | 08:05 AM
b18bturbo's Avatar
Default Re: Challenges of turboing an OBDII integra? (Arturbo)
obdII in tx is great thing they dont even do sniffer emmision on the obd II stuff just hook it to your ecu to check for codes.
Old Mar 12, 2003 | 08:10 AM
boostin b16's Avatar
Default Re: Challenges of turboing an OBDII integra? (b18bturbo)
obdII with no codes!! well ... except for the occasional 71-74 misfire. no real challenges unless you want to run 20+psi.
Old Mar 12, 2003 | 08:25 AM
Default Re: Challenges of turboing an OBDII integra? (boostin b16)
My car will not see 20psi!! It's a real nice thought but knowing the way I drive I can honestly say I would never "really" need that much. This time around I will be using a hondata instead of a VAFC but I can't imagine that the car would ever see anything over 1 bar. In fact I think 10-12 psi is more realistic.
The concerns that I am having about the OBDII ecu is I keep hearing stories about CEL codes popping up all the time and all those damn emission sensors. How much of this is true and how much is just misinformation I don't know. But now that I think about it I really should re-phrase my question...
Since I plan to use a hondata this time are there any issues I should anticipate with an OBDII car? I'm assuming that I will have to do an ecu swap to make it work correct, and if that's the case do I have anything to worry about at all?
Old Mar 12, 2003 | 08:33 AM
2K_TEG's Avatar
hondata recently came out with OBD1 chipped P28 ECU with OBD2 connectors on the ECU. NO CONVERSION HARNESS. They make the whole conversion a snap.
Old Mar 12, 2003 | 08:48 AM
@irborne's Avatar
Default Re: Challenges of turboing an OBDII integra? (2K_TEG)
that is an excellent advancement.
Old Mar 12, 2003 | 08:51 AM
Kyle can you provide those?
Old Mar 12, 2003 | 09:07 AM
2K_TEG's Avatar
yep. IM, e-mail for prices, I cannot post any hondata pricng.
Kyle
Old Mar 12, 2003 | 09:13 AM
Kyle
done!
Old Mar 12, 2003 | 09:16 AM
MikeMAN's Avatar
same here in WI!! takes like 1 minute to get emmisions tested!
Old Mar 12, 2003 | 09:51 AM
mamaboy's Avatar
obd2 is only an issue with hondata because you have to purchase all the riggin to make it work...you can always use the apexi power fc or the ems....they'll all end up being the same price across the board....almost
Old Mar 12, 2003 | 11:03 AM
Trac226's Avatar
Damn you Texas guys
Conversion to obd1 or having that secondary o2 sensor might be a problem. But if that p28 can hook up, that's great.
Old Mar 12, 2003 | 11:46 AM
LiLOtaku's Avatar
Default Re: Challenges of turboing an OBDII integra? (Trac226)
So what do guys with hondata's do when emission comes around on there obd2 cars with obd1 ecu's?
If your car is turbo'ed, bigger injectors, ..etc.etc. do you just have to revert your car back to stock in order to pass emissions?
Old Mar 12, 2003 | 01:34 PM
Diego Boost's Avatar
Default Re: Challenges of turboing an OBDII integra? (LiLOtaku)
Yup. Gotta put the stock ECU, header, etc.
Old Mar 12, 2003 | 02:40 PM
Default Re: Challenges of turboing an OBDII integra? (Diego Boost)
Are you serious? Art do you have to do that too?
Old Mar 12, 2003 | 02:43 PM
DIRep972's Avatar
Smarter than you
well either way, if u want to pass legally you are gonna have to convert the car back to stock. obd1 or obd2. unless u want to run closed loop wastegate, route ur bov back into the intake, and run a cat it still won't pass a visual. Its very easy to get a sticker, and the paperwork to go along with it. You just have to know the right people. Jim, trust me, u know the right people
Old Mar 12, 2003 | 02:50 PM
DvSiR's Avatar
Default Re: Challenges of turboing an OBDII integra? (DIRep)
buy an aem and a wide band 02 like a U.E.G.O., universal exhaust gas oxygen sensor, 7 wire 02, you can get them from motec for like 200-300.
FliiBoii
Nov 19, 2011 06:28 PM
blowme
Jun 29, 2005 04:58 PM
stickeyfingaz
Jul 30, 2004 04:36 PM
89civicdx
Mar 4, 2003 11:10 AM
