SS brake lines
Old Mar 11, 2003 | 11:35 PM
98type_r's Avatar
New User
Default SS brake lines
i'm replacing the rotors/pads next week and a friend suggested i replace the brake lines with some ss lines.
is this a worthwhile investment or not on a daily driver, with very light track usage?
Old Mar 11, 2003 | 11:49 PM
Bbasso's Avatar
Default Re: SS brake lines (tie par)
https://honda-tech.com/zerothread?id=421354. for some info.
I looked quick but did not find the thread about the wear-n-tear of SS lines. The conversasion was that they might have to be replaced every year for safety reasons...
Old Mar 12, 2003 | 06:03 AM
Cosworth's Avatar
Default Re: SS brake lines (Bbasso)
Yep, you just gotta keep an eye out for the SS lines. Maybe every other oil change should suffice.
Rubber brake lines give you a warning before they quit, SS lines will not give much of a warning before they fail. Hence, need to check 'em every so often.
Old Mar 12, 2003 | 06:29 AM
jond's Avatar
Default Re: SS brake lines (Cosworth)
I talked to the service manager at Acura, and he said as long as you change your brake fluid every other year, SS lines should last the life of the car.
Old Mar 12, 2003 | 06:32 AM
onyx00's Avatar
Default Re: SS brake lines (jond)
Until a small rock gets embedded in the steel weave of the line and causes it to fail and you go back to Acura and they say it's not their fault that your wife and three small children and all dead because you couldn't stop and you rammed in to a semi and it cut all your heads off and you are all dead now.
Old Mar 12, 2003 | 06:34 AM
jond's Avatar
Default Re: SS brake lines (onyx00)
I think Im going to stick with stock brake lines....
Old Mar 12, 2003 | 06:37 AM
Dave-ROR's Avatar
I see no need for them. Honda brake lines are quite good actually. Make or buy a MC brace if you want firmer pedal feel.
Old Mar 12, 2003 | 06:40 AM
Willard's Avatar
Default Re: SS brake lines (FyrStarter)
yup..
once the car is 10+ years old... then it will be time for replacement.
Old Mar 12, 2003 | 06:46 AM
Cosworth's Avatar
LHT MC brace is a true bolt-on product w/ good quality. Only about ~$50. Highly recommended for better pedal feel. With LHT MC brace, the difference is night and day.
Old Mar 12, 2003 | 07:03 AM
onyx00's Avatar
Where can I get one?
Old Mar 12, 2003 | 07:04 AM
io_burn's Avatar
New User
What has always confused me is if SS lines are so vulnerable, why doesn't anyone make SS lines that are covered in some kind of protective plastic coating? That way you get the benefit of the SS and the durability of standard lines? Maybe they do make these, who knows... I just always thought of this whenever anyone posts about rocks getting stuck in the weave of stainless lines.
Old Mar 12, 2003 | 07:35 AM
hypa's Avatar
Default Re: SS brake lines (io_burn)
I've been running SS lines for just over 2 years on my GSR and they are still mint. They not only gave me a much firmer pedal feel, but also gave me the excuse I needed to change my fluid out for some Motul.
to SS brake lines.
to skepticism
Old Mar 12, 2003 | 08:39 AM
Dave-ROR's Avatar
Default Re: SS brake lines (hypa)
to SS brake lines.
to skepticism
You changed brake lines to have an exuse to change fluid? That's retarded.
If you want to change fluid, CHANGE THE FLUID.
If you want better pedal feel with less effort and less $ get a MC Brace. SS Lines on an ITR do not feel much better than stock and tehy are not worth doing as there is NOTHING wrong with the OEM lines are you are not improving performance at all.
Old Mar 12, 2003 | 08:49 AM
.RJ's Avatar
.RJ
Motul fluid will give the car a noticeably firmer pedal feel, when compared to OE or ATE fluids.
Not a very scientific comparison.
Old Mar 12, 2003 | 08:56 AM
Dave-ROR's Avatar
Default Re: SS brake lines (.RJ)
I wasn't making fun of his choice of fluid RJ. Simply that he used the lines as an *EXCUSE* to change to Motul.
Old Mar 12, 2003 | 09:06 AM
Willard's Avatar
You will have to explain this to those watching at home.
How can you determine the difference in compressibility of two different liquids?
Old Mar 12, 2003 | 09:07 AM
.RJ's Avatar
.RJ
Default Re: SS brake lines (Willard)
*runs off to search google*
Old Mar 12, 2003 | 09:13 AM
.RJ's Avatar
.RJ
I cant seem to find a chart comparing compressibility values for common racing fluids - however i've felt the effects of this first-hand. The cost of Motul was too much for me to keep using it though. Bleeding my brakes 15 times a year, its not like i dont know how do that job.
While our HS chemistry teachers tell us liquids do not compress, this is only partially true. At high temps and pressures, liquids will compress a small amount. While i didnt see any charts comparing compressibility, i saw the figure "1200psi" a few times. Maybe this is an industry standard?
Old Mar 12, 2003 | 10:06 AM
Phoenix_ITR's Avatar
Old Mar 12, 2003 | 10:16 AM
Dave-ROR's Avatar
Default Re: SS brake lines (delinquent)
Well.. I just drive there or call..
but..
IM "scooter" or "CRVRX" on HT.
Old Mar 12, 2003 | 12:10 PM
Willard's Avatar
Becasue there is no such thing. IIRC
Yes... they 'can' compress but it is a negligible amount.
At elevated temperatures... fluids expand.
do you mean 12k-bar?
Old Mar 12, 2003 | 12:15 PM
Johnny Tran's Avatar
# 1 ...own3d
#2 engineers suck...
nick, who feels the need to mention more than 1/2 of the we-todd krew are engineers
[Modified by Johnny Tran, 4:16 PM 3/12/2003]
Old Mar 12, 2003 | 12:19 PM
Dave-ROR's Avatar
Default Re: SS brake lines (Johnny Tran)
# 1 ...own3d
And the rest of us dropped out of engineering majors in college to make bling. except realtyper, he's retarded
Old Mar 12, 2003 | 12:23 PM
GRM Scott's Avatar
25 Year Member
Neuspeed lines have a coating of some sort, D has some pix on the site i think, he's got them. Dunno if anyone else uses these, i've always thought they looked pretty good.
at least he's not mega-retarded, like mike@ **** imports
