My next mod. P28 chipped ECU???!
Old Mar 11, 2003 | 05:57 PM
B00ST2nR's Avatar
Default My next mod. P28 chipped ECU???!
What ECU should I get and what chip program should I get?? I don't know much about ECU's...
Old Mar 11, 2003 | 06:20 PM
threatcon13's Avatar
New User
Default Re: My next mod. P28 chipped ECU???! (Skunk2nR)
why would you want a chipped ecu yo????! you can get a p28 w/ hondata s100 !!!?!?!?!?! That way you can change your fuel and ignition maps and dyno tune with the addition /removal of mods !!!!!!!?!
Old Mar 11, 2003 | 06:30 PM
95lsteg's Avatar
Default Re: My next mod. P28 chipped ECU???! (Threatcon13)
How much can cost a setup like that?
Old Mar 11, 2003 | 06:35 PM
New User
Default Re: My next mod. P28 chipped ECU???! (95lsteg)
Around 500?!!! (rough estimate) for an obd1 car!!?!? For an obd2 car, add in 200 for an obd1 ecu, and 250 for an obd2 to obd1 harness!!?!!
Old Mar 11, 2003 | 06:41 PM
StinkyTofu's Avatar
Hondata route is much more expensive. However, I think its worth it since not 1 chip is designed for your specific car.
Hondata s100 = 245
P28 ecu = ~130 + however much its gonna cost to Hondata Modify it (which is basically buying a chipped ecu to begin with)
Obd2-Obd1 Harness = Around 170
Tuning = This is probably gonna kill you the most. Depending on your tuner, expect to pay around ~100 per hour.
Old Mar 11, 2003 | 06:59 PM
B00ST2nR's Avatar
Default Re: My next mod. P28 chipped ECU???! (StinkyTofu)
its 180 an hour at DSR... that's where I am goin to get my car tuned. Best Tuner in Norcal IMO.
I guess I'll hold off on the ECU upgrade till later. Costs way too much for my budget.
Old Mar 11, 2003 | 07:08 PM
StinkyTofu's Avatar
I highly recommend you get a chip with your cams. Chipped ecus are often overlooked and shouldn't be. You're running different internals, and so your stock fuel and ignition timing maps and a/f ratio should be altered to maximize power with your cams. Not to mention, you should be running a higher redline because you are making power past 8100. Running a higher redline will separate you from the average gsr on the road. You said in one of your other posts that you were gonna tune your car soon anyways, so might as well tune it with a chipped ecu. Well thats just my opinion. If you get a chip later, you're gonna have to pay again for tuning. Just be patient
[Modified by StinkyTofu, 8:09 PM 3/11/2003]
Old Mar 11, 2003 | 07:12 PM
B00ST2nR's Avatar
Well... I have to get Valvesprings, Ti-Retainers, JDM 4-1 Header, 2.5 inch Carsound Cat., and the p28 chipped ECU all installed before I dyno tune it.
That's my next project.
But for now, I just gotta get my Skunk2 Intake Manifold, ITR AEM CAI, and the Cams and Cam gears in and Tuned so I can ride around.
Old Mar 11, 2003 | 07:38 PM
Aaron M's Avatar
kenji
Old Mar 12, 2003 | 04:52 AM
JumbosGS-R's Avatar
New User
Default Re: My next mod. P28 chipped ECU???! (SilverB18C1)
Man, how many jobs do you have that you are buying all this stuff so fast? I'm jealous.
Old Mar 12, 2003 | 06:21 AM
26R's Avatar
26R
Default Re: My next mod. P28 chipped ECU???! (JumbosGS-R)
Hey Skunk2nr, if you have the skunk2 manifold are you still running the stock GSR throttle body? If you are, get rid of it and find a 62mm or bigger, big difference when I did that, I didn't feel any difference in the manifold until I got my Type-R throttle body, just a little FYI.
Also don't mess around with those chip programs, go Hondata, you will not regret it.
PaJeeZy
Northern California (Sales)
Apr 5, 2009 02:57 PM
Milab21
Mar 26, 2008 05:05 PM
SuperImport
Apr 16, 2005 04:22 PM
DohcRex
Feb 9, 2003 02:53 PM
