HELP! Spark Plugs fouling after 2 high boost runs?
Old Mar 11, 2003 | 04:36 PM
dmecarboy's Avatar
Default HELP! Spark Plugs fouling after 2 high boost runs?
Heres the problem, My plugs foul out or just don't work after a few hard runs. I'll put new plugs in and the first couple of runs are good, but go bad after that. I've tried all gaps with the same problem I can drive the car around town and on the highway no problem. It's when I take the car above 6k it starts to bang. I've checked the plugs and they look good. The list below is what I'm running along with the plugs I'm using! Any help would be great!!!
NGK R5672A-8 and NGK wires
JE 9:8.1 pistons
Eagle rods
Crower valve train
P+P head
Precision T3/T04E 60-1
XS eng intercooler
Crane ign and coil, msd cap
SFP exhaust manifold
TIAL35mm wastegate .80 spring
RC 550cc inj
AME fuel rail
SX fpr
jg/edl intake man
Apexi Power FC
Apexi AVCR
Theres more but thats the basics, Please help!!!
Old Mar 11, 2003 | 05:26 PM
BoostedSi's Avatar
Default Re: HELP! Spark Plugs fouling after 2 high boost runs? (dmecarboy)
What heat level are those plugs. I'm using ngk bkr7e and they work fine so far. But then again i havent tuned in high boost yet...only got to 9psi cause turbo seals were blown.
Old Mar 11, 2003 | 05:27 PM
genop's Avatar
Default Re: HELP! Spark Plugs fouling after 2 high boost runs? (BoostedSi)
is the power fc tuned? Could it be a bad map?
Old Mar 11, 2003 | 07:10 PM
dmecarboy's Avatar
Default Re: HELP! Spark Plugs fouling after 2 high boost runs? (genop)
The heat range is 8, the power FC was tuned at Carboy in Houston. There a authorized power excel shop!
Old Mar 11, 2003 | 07:33 PM
ninesecrx's Avatar
its your tune up...plain and simple
Old Mar 11, 2003 | 07:52 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: HELP! Spark Plugs fouling after 2 high boost runs? (ninesecrx)
the problem is most likely your distributor. check the rotor brush and cap.I know it sounds far off but i had the same exact issue and that was the problem. I'm willing to bet 99% that is your issue. let me know.
Old Mar 12, 2003 | 03:07 AM
dmecarboy's Avatar
Default Re: HELP! Spark Plugs fouling after 2 high boost runs? (MotorMatrix.com)
I have a new type r rotor in my tool box. I'll switch it out tomorrow and see if it helps! Thanks everyone for all your input!!!
Old Mar 15, 2003 | 03:12 PM
dmecarboy's Avatar
Changed the rotor, plugs and wires and still have the problem. I'm going to change the cap this week!
Old Mar 15, 2003 | 04:39 PM
I am a bad person
Change the cap and I bet it will fix it. I was experiencing the same exact issue and seemed like a long shot but it worked immediately.
Old Mar 25, 2003 | 10:37 PM
TurboDANDEE's Avatar
do you drive a blue integra?
Boostinb20!
Jul 16, 2009 02:33 PM
john d
Aug 22, 2006 08:00 AM
u_tal
Nov 10, 2004 03:01 PM
96turbob18c
Jun 20, 2004 08:52 PM
