93 delsol, rear lca bolts broken, sway bar install.
Old Mar 11, 2003 | 08:34 AM
SoloSol's Avatar
Default 93 delsol, rear lca bolts broken, sway bar install.
Ok, here is the deal, both rear lca bolts are broken the heads sheared right off.
Now I have aquired a progress 22mm rear bar with all the hardware.
To install this I have to spin(rotate 180) the rear shocks right? I will have to heat and remove the welded nuts that are attached to the shock. Can i just get new rear bolts and nuts then install or is there something else I need to do?
Blacknight117
Suspension & Brakes
10
Sep 3, 2012 08:37 AM
Valetin831
Nov 26, 2008 11:16 PM
charliemopps24
Apr 30, 2007 09:12 AM
MISFITofMAGIC
May 21, 2006 11:14 AM
p0pe
Jan 13, 2004 12:36 PM
