leaning out what FP psi b16a
our setup is b16a Wtih Jackson Racing Supercharger. skunk2 stage 1 cams, ,i/h/e, . what kind of pressure should i be running. everything is adjustable.
no. thats why i said everything is adjusable. i have fpr, rail, wlabro 225 fuel pump, jackson fmu, injectors. plus i have the aem ems ecu but dont be scared off by that because we are taking the car to michigan for tuning with that. i am not going to mess with the aem ems right now. the problem is the car will idle fine but it will only take like 10% throttle and it wants to die, the air/fuel gauge goes way into lean. i cant drive it up there like this so i need peoples psi's so i can go from there.
turned the pressure to 45-50 and messed with the timing alittle and now its about 60% better then it was before. i also messed the the fuel map and increased that by 15% or so and that kinda solved the problem. oil leak still killin my fun... thanks 88crx91integra and others for the help
[Modified by toyosupr, 8:21 PM 3/11/2003]
superturboprelude
May 27, 2007 08:34 AM
