GE vtec conv. kit ..help
Old Mar 11, 2003 | 04:17 AM
torr's Avatar
Default GE vtec conv. kit ..help
i got the golden eagle vtec conversion kit and i know that the fittings for the oil line is a -6an. i've already spent money on two different lines, but the damn things don't want to tighten up, any ideas guys. the lines i got are -6an lines, they have the correct fittings but everytime i go to scew it on the lines won't tighten up. the thing still free spins. what kind of lines are you guys using. thanks
Old Mar 11, 2003 | 05:32 AM
BROOD's Avatar
Default Re: GE vtec conv. kit ..help (torr)
How about a picture of what is going on? Maybe something that points out exactly what fittings are not tightening up? It would help us out.
I'm using the GEM oil filter block also.....my 6AN Earls hose ends fit fine. What line kits are you using?
Old Mar 11, 2003 | 05:34 AM
Sleeper's Avatar
Make sure that the lines are fully seated in the hose ends before you tighten the fitting to the hose. Are the fittings tight on the hose? Did you install the -6AN/3/8NPT head adapter from the GE kit?
This is what I used:
-6AN SS line
-6AN hose ends, swivel type
-6AN/3/8NPT adapter for head
Old Mar 11, 2003 | 05:49 AM
torr's Avatar
Default Re: GE vtec conv. kit ..help (Sleeper)
i'm using the fittings that came with the ge kit. i ordered a ss line from a local auto parts store, it came with a 6an female connecter on both ends. when i screw it into the male ends of the fittings that came with my ge kit it goes on tight but the female end of the ss line still swivels. isn't the connector on the line suppose to tighten up with the ss line. and no i can't get pics. right now because the line is at my house and i'm at work. thanks
Old Mar 11, 2003 | 05:59 AM
Sleeper's Avatar
Is it a swivel type fitting like this?http://store.summitracing.com/global...m-221303_m.jpg If so its ok, its supposed to do that.
Old Mar 11, 2003 | 06:19 AM
torr's Avatar
nah it looks like this http://www.holley.com/HiOctn/ProdLin...A/SSBHose.html
done
Aug 23, 2008 08:12 AM
Mr_ET
May 15, 2007 02:23 PM
deeweezy
Aug 9, 2003 06:24 PM
vtec.dc2
Apr 8, 2003 11:48 AM
