Junkyard HIDs?!? What cars ballasts will work?!? (searched)
Old Mar 10, 2003 | 07:22 PM
TypeR 01 886's Avatar
Default Junkyard HIDs?!? What cars ballasts will work?!? (searched)
I was wondering, if I went to a junkyard, what car should I look for to get the HID system out of and use for my car?!? (which is the easiest to get at?) I know it wont be plug and play, I will have to do some wire work (im good at that stuff). Has anybody ever tried this, and is there a particular car I should try and get the HIDs/projectors from.
I have seen the post of the Audi projectors, If I see an audi I will take the projectors; but I am more interested in the HID system it self. Also, any idea how much they would charge me for these? Just a thought.
Old Mar 10, 2003 | 07:30 PM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default Re: Junkyard HIDs?!? What cars ballasts will work?!? (TypeR 01 886)
Well, i got my HID's off an Acura CL-S and most ballasts should be compatible with your car. Most OEM ballast only consume 35 watts of power. Your low beams i think use 45 watts of power. Its pretty simple if you're good with wiring. There will be 2 wires ( pos. and neg.). All you need to do is connect those wires to your low beam wires. Just connect the positives and negatives and you're good. Make sure the bulbs are in and test out the bulbs. the OEM ballasts have a different connector to the bulbs compared to the retrofit bulbs so make sure that you have the matching connecting ends so that they fit. If you use standard HID bulbs then you will need to do some modifications. you can PM me or email me if you need some help getting those bulbs into the housing of your Teg headlights if thats where they're going. I posted up some instructions on a thread about getting HID's into Non HID JDM headlights so if you can find that thread, i got some info. I don't have any pics so hang in there with me but find the thread and let me know if you need help.
Old Mar 10, 2003 | 08:39 PM
Default Re: Junkyard HIDs?!? What cars ballasts will work?!? (Nvious R)
Thanks alot man! Very imformative post, I am heading to the junkyard tomorrow to see what I can find. I am going to be mainly looking for BMW's Audi's Acura's Lexus. etc...
Thanks again for the info!
Old Mar 10, 2003 | 09:05 PM
JimmieD's Avatar
my ballast and bulbs are out of a newer cadillac and everything worked out ok in terms of hooking them up and turning on. my only problem is that i believe i need different bulbs due the caddy being a reflector lens and my car having projectors. my light ouput is not what i expected
Old Mar 10, 2003 | 09:08 PM
JohnnyBoy's Avatar
Default Re: Junkyard HIDs?!? What cars ballasts will work?!? (JimmieD)
All of the ballasts can work....just try to get D2S bulbs...not D2R
BMW X5, 5 Series are very similar to the Phillips kits.
Old Mar 10, 2003 | 09:15 PM
Dave-ROR's Avatar
RICE BOY!
Posted for MK Ultra so he didn't have to waste his time
the_dxB16
Lighting
10
Jan 11, 2009 10:10 PM
BakktoJDM
Honda Civic (2001 - 2005)
Apr 16, 2008 10:21 AM
exsuntechnology
Lighting
Nov 29, 2007 04:51 PM
1sikhatch
Jun 18, 2006 08:54 PM
.ShawnD.
Sep 29, 2003 05:10 PM
