squeaky fan?
Old Mar 10, 2003 | 04:15 PM
95TEG's Avatar
Default squeaky fan?
My fan for my heat and ac started squeaking. Its sounds like a cricket almost. It doesnt matter weather i have the ac on or not. As long as the fan is running it is squeaking. Can I fix this? Has anyone ever had this problem? Thanks in advance.
Old Mar 10, 2003 | 05:03 PM
95TEG's Avatar
Default Re: squeaky fan? (95TEG)
ttt
Old Mar 10, 2003 | 05:34 PM
ThrillaKilla's Avatar
yeah you need to replace the fan, this hapened in my 90 integra, usually the first 2 settings go out on the heat control then the bearing starts squeaking.. you can probably just lube it up but i just replaced it because the prev. owner threw one in (wonder if he knew it was goin bad )
Old Mar 10, 2003 | 06:43 PM
b19coupe's Avatar
You might just have leaves or other debris in the squirrel cage. Drop the blower motor and look. If there is nothing in the squirrel cage, the blower motor itself is probably failing.
Old Mar 10, 2003 | 07:21 PM
95TEG's Avatar
Default Re: squeaky fan? (b19coupe)
how hard is it to drop the fan itself?
Old Mar 11, 2003 | 03:30 AM
b19coupe's Avatar
One connector and three screws-the hardest part is working it out from the tight space.
stinkbox
10
Sep 15, 2011 02:02 PM
lordfuzzz
Jan 13, 2010 01:43 AM
6speed-ferio
May 4, 2007 10:46 PM
kurokojin
Aug 17, 2006 10:37 PM
