squeaky fan?
My fan for my heat and ac started squeaking. Its sounds like a cricket almost. It doesnt matter weather i have the ac on or not. As long as the fan is running it is squeaking. Can I fix this? Has anyone ever had this problem? Thanks in advance.
yeah you need to replace the fan, this hapened in my 90 integra, usually the first 2 settings go out on the heat control then the bearing starts squeaking.. you can probably just lube it up but i just replaced it because the prev. owner threw one in (wonder if he knew it was goin bad
You might just have leaves or other debris in the squirrel cage. Drop the blower motor and look. If there is nothing in the squirrel cage, the blower motor itself is probably failing.
stinkbox
10
Sep 15, 2011 02:02 PM
