92-93 Integra LS Distributor work with P75 ECU for B20 Swap?
Old Mar 10, 2003 | 12:48 PM
Tr0LL's Avatar
Default 92-93 Integra LS Distributor work with P75 ECU for B20 Swap?
I know I need an OBD-1 distributor for my b20 swap into my 93 Civic. I'm pretty sure the 92-93 integra LS distributor is OBD-1. I was wondering if I can use the 92-93 integra LS distributor for my b20z swap into my 1993 civic dx. I will be using a P75 or P74 OBD-1 ECU from a 94-95 integra....
On a side note, if I can use the 92-93 distributor, wouldn't the 92-93 integra ECU also work? I dont' remember reading anyone using using the 92-93 integra ecu for their b20 swaps in their 92-95 civics. Any reason to this?
Old Mar 10, 2003 | 01:54 PM
Katman's Avatar
Default Re: 92-93 Integra LS Distributor work with P75 ECU for B20 Swap? (Tr0LL)
yes you can use a 92-93 DA LS distributor in your EG, and you can use any OBD1 LS ECU (PR4/P74/P75) in conjunction with the 92-93 LS dizzy. It's all compatible with each other because it's all OBD1...and so is your EG.
Old Mar 10, 2003 | 02:20 PM
Tr0LL's Avatar
Default Re: 92-93 Integra LS Distributor work with P75 ECU for B20 Swap? (Katman)
thanks katman.... i wish jdmhondaparts had some b20z's in stock.... I'd pick one up right now if you guys did..... Now I have to look around for a b20z.....
Old Mar 10, 2003 | 02:38 PM
Katman's Avatar
*shrugs shoulders* sorry! sheng runs the show ... I just chip ecu's
1987HondaCivic
Jul 10, 2015 07:41 AM
philafelman
Sep 14, 2003 11:41 AM
