Need opinions on a CRAZY engine swap
Old Mar 9, 2003 | 10:59 PM
No More Civic's Avatar
Default Need opinions on a CRAZY engine swap
Ok, I found a place that sells 3S-GTE engines from the turbo MR2 for about $1k. I was thinking that since the engine is set up just like our engines, then with a little fabricating, I might be able to put one in a Civic or CRX. What does everyone think of this idea.
Old Mar 10, 2003 | 01:58 AM
silverkorn's Avatar
Default Re: Need opinions on a CRAZY engine swap (SlowCivicDX)
i dont think its worth it. too much money for custom fab'ing to have the engine in there and running right. just think about all that wiring your going to have to do to have it match up. but thats just my 2 cents
Old Mar 10, 2003 | 08:01 AM
ZetecOwns's Avatar
Default Re: Need opinions on a CRAZY engine swap (silverkorn)
What kind of transmission would you be using?
Old Mar 10, 2003 | 08:52 AM
Default Re: Need opinions on a CRAZY engine swap (ZetecOwns)
Well, I'll be using the MR2 tranny, and I really don't see the wiring being that big of a problem. Yeah it'll would be a little bit of a pain in the *** to install it, and if it was that big of a problem then I could always get a stand alone. When I think about it, the main problems I would have is getting motor mounts, exhaust piping, and figuring out how to get the drive wheels to bolt up right.
Old Mar 10, 2003 | 08:53 AM
E-AT_me's Avatar
hate to be an a-hole, but why waste the money? is that motor more capable then a b-series?
Old Mar 10, 2003 | 09:00 AM
JalopySiR's Avatar
Default Re: Need opinions on a CRAZY engine swap (Rexman)
Yeah a 3SGTE is WAY more capable than any B series engine. JGTCC supra's swapped out the 2JZ in favor of the 3SGTE, as it allows for larger turbos, radiators, intercoolers, etc, and is more than capable of over 700hp. But I digress, If you are thinkin' hey these are cheap I'll just slap on then, Umm you got a whole lotta headache coming your way. EVERYTHING will have to be custom. Not worth it IMO. It says in your sig you have an MR2, Mod that thing with a 3SGTE, and use a B series for your honda.
Old Mar 10, 2003 | 09:12 AM
Default Re: Need opinions on a CRAZY engine swap (JalopySiR)
See, that's the thing, if I put the 3S-GTE into a Civic or CRX, then I won't have to worry about cosmetics. Where as, my MR2 needs a new front bumer, since alot of the clips on it are broken and it also needs a new paint job. So, by the time I spent the money on swapping the engine into my MR2 and got it looking nice, I could have swapped it into a Civic or CRX that I would buy without an engine for a couple hundred dollars. So reguardless, I'm going to end up spending around the same amount of money. The way I look at it, why not be very different and put the engine in a Honda?
Old Mar 10, 2003 | 09:22 AM
*Boostwerks*'s Avatar
just spend the damn money and build up the MR2...
That is the best option for you IMO.
keep the civic as the "every day beater".
[Modified by Bryson, 11:22 AM 3/10/2003]
Old Mar 10, 2003 | 09:35 AM
89civic1.8T's Avatar
Default Re: Need opinions on a CRAZY engine swap (Bryson)
I would say go for the Toyota engine! It's your car and if thats what you want and you have the time + $ to do it go for it!!!
Old Mar 10, 2003 | 09:39 AM
WuShu's Avatar
New User
Default Re: Need opinions on a CRAZY engine swap (89civic1.8T)
my hat off to you for considering this swap. However my only suggestion is to really consider exactly what its going to take to make this work, its going to take 100% custom fabrication, go through everything that it would possibly take then remember that more than 75% of most of the expenses are gona come from small dumb things that are gona pop up.
Old Mar 10, 2003 | 10:04 AM
Steve91's Avatar
Bad idea. First of all, for the money you would have to spend to get it right, you could drop in a fully built Dart B18 that would handle 900 hp or more.
There are too many thing you would have to fabricate from scratch to make this work.
Old Mar 10, 2003 | 11:05 AM
Default Re: Need opinions on a CRAZY engine swap (Steve91)
Have you even though of how much it would cost to build and engine with a Dart block? The block alone is $2k, and then you still have to buy a crank, rods, pistons, a head, tranny, wiring, mounts and axles. That would actually end up costing me more than putting the 3S into a Civic. And I would truly love to build an engine with a Dart block. And also, I wouldn't go with the B18, I'd get the B20 stroker block, since they're the same price.
Old Mar 10, 2003 | 11:19 AM
No one should want a Dart block....
1. You can't use 900Hp on the street.
2. It is not NHRA legal
3. A GE sleeved block can handle pretty much anything and is WAY cheeper
so.....WHY HAVE IT?
Old Mar 10, 2003 | 11:44 AM
darkracer's Avatar
<U>IMO</U> Honda should stay honda. Hondas have been beating all the other cars out there with the motors that come in them. Hondas don't use huge displacement or lots of turbo to beat other cars, we use technology and finese. If we decide to go turbo, we kill even harder. In my state of HI i saw a rex with a wide body conversion and FORD FOCUS LIGHTS IN THE BACK!!!! I was kind of sick, it wasn't that ugly, but i just didn't like it. I appreciate the effort he put in, but up to you and your wallet. just my 2 cents. peace.
Old Mar 10, 2003 | 11:53 AM
Shawn C's Avatar
In The Garage
you'll need custom axles made, you'll need a custom mount kit made, and you'll have to re-wire the car to think its an MR2, MR2 computer, blah, blah, blah exhaust is nothing, i think the wiring would just be a nightmare, but cool idea. if you've got the patience, time, and money, go for it! i would love to see it, just do a clean-*** install.
Old Mar 10, 2003 | 12:23 PM
d357r0y's Avatar
i wanted to put one of those motors in my 65 chevy corvair.
i say go for it!
BadFoxDragon
Apr 1, 2019 05:59 AM
bauer10
Apr 21, 2006 12:37 PM
ComptonsF1NEST
Mar 10, 2006 08:21 PM
numbnuts22715
Welding / Fabrication
36
Sep 24, 2004 10:40 AM
sCeRaXn
Mar 2, 2003 10:16 AM
