boost on ef
You could upgrade the fuel pump to a 255 lph unit, bigger injectors, or an FMU (Fuel Management Unit, made by Vortech.) That would give more fuel depending on boost. Im new to turbos, so hopefully this is correct info I am giving you. Someone correct me if I am wrong.
Daniel
Daniel
Depends what you consider not a lot of money, if you have $300 - $50 for 450cc injectors, $250 used VAFC. Run the VAFC hack.
EDIT: SAFC hack in your case.
[Modified by beta13, 6:54 PM 3/9/2003]
89 CRX SI
Feb 3, 2004 06:01 PM
99blusi
Sep 15, 2003 02:06 PM
