smoke from turbo? HELP
Old Mar 9, 2003 | 12:45 PM
DimSum321's Avatar
Default smoke from turbo? HELP
hey guys, i have a garret t28 on my b18c1 and i havent been boosted long. i run 5psi but i noticed that when i make a few hard runs, when i pop the hood there is smoke coming from the turbo. it looks like its coming from the underside where the intake/compressor side bolts onto the exhaust/turbine side. There is also a little bit of oil in the compressor inlet, but theres no oil in the BOV or anything, so i dont know whats wrong, anyone got any ideas?
Old Mar 9, 2003 | 01:23 PM
Therumblingteg's Avatar
Default Re: smoke from turbo? HELP (DimSum321)
you have most likely burned your turbo and need to rebuild it.
Old Mar 9, 2003 | 01:35 PM
420aNT's Avatar
Default Re: smoke from turbo? HELP (Therumblingteg)
No thats not necessarly true. He cold have a leak from his feed or his return line as well.
Old Mar 9, 2003 | 01:56 PM
MiraiZ's Avatar
Default Re: smoke from turbo? HELP (18gTeg)
any number of possibilities actually...it may not be the turbo at all....could be serious blowby and oil getting into the compressor...or a blown HG and oil getting into the exhaust...leaky tubo seals....do a check on the engine first...make sure that its healthy..
Old Mar 9, 2003 | 04:34 PM
DimSum321's Avatar
o yea i do have a leak on my oil return line. but its at the oil pan where the flange was welded into it. i didn';t think that would have an effect. the smoke isn;t bad at all and doesn;t last long
hold your breath
Feb 14, 2007 10:01 AM
Blkteg97
Nov 16, 2004 08:04 AM
khmboostedeh2
Sep 4, 2004 07:45 PM
