Cam timing.
Old Mar 9, 2003 | 11:56 AM
simplestyles's Avatar
Default Skunk Stage twoCam timing
okay so I just installed skunk two cams into a b16. for optimum power the instructions say to set the cams to the following specs:
intake:
opening @ 1 mm: 37 deg. BTDC
Closing @ 1 mm: 49 deg. ABDC
Exhaust:
Opening @ 1mm: 61 deg. BBDC
Closing @ 1mm: 21 deg ATDC
I dont have a 360 deg table to bolt to the cams so I can see where they are. I do have adjustable cam gears. Does anyone know a good setting for these with cam gears while keeping the valve to piston clearance good?
thanks ahead of time any thing will help.
Paul
[Modified by simplestyles, 11:28 PM 3/9/2003]
Old Mar 9, 2003 | 09:31 PM
Default Re: Skunk Stage twoCam timing (simplestyles)
someone any one. I have them set but not much difference. I need the best setting if someone knows
Old Mar 9, 2003 | 09:41 PM
Padawan's Avatar
Darth ModerVader
The best settings will only be found on a dyno.
dbiker207
Jun 9, 2007 09:02 AM
anthony90si
Sep 28, 2006 08:34 PM
saso
Sep 27, 2003 07:52 AM
bananacruzier
Feb 4, 2002 05:52 AM
